BFG KM2s- 33/10.50/15 or 32.11.50/15 - JeepForum.com
post #1 of 22 Old 01-18-2009, 06:40 PM Thread Starter
ipodblue12
ok guys, so i have a 2000 Jeep Wrangler.
D44/D30 Combo-3.73 gears.
5 speed Manual.
I am getting a 2.25in. BB with Blisten Shocks and a 1.25 JKS BL
it is a daily driver and no serious offroad as in no flexing and no serious mud.
So the question is which size BFG KM2?
33-10.50-15:
-51 LBS
-32.8-OD
32-11.50-15
-49 LBS
-31.8-OD
Should i get the extra inch, less weight and narrower or less inch but wider and heavier?
ipodblue12 is offline
post #2 of 22 Old 01-18-2009, 08:19 PM
doogie
doogie's Avatar
According to the numbers below the 32's are lighter....but only by a few pounds so weight wouldn't be my deciding factor. In my own opinion I would go with 32's. I think 33's look a little cramped under a BB even with a BL. Yeah you can do it. But if it were mine I'd go with the 32's. It will help keep a little power with the smaller dia and keep some space under those fenders.
Trust me one day you will want to flex without rubbing your fender flares off.
Nationalmssociety.org
Current = 1996 XJ, 2.5, 2-Door, 5-Speed, 4.88's, 3.5" Mix-N-Match, Black 15" KMC XD122's, 31" BFG AT's, RE QD's
My current XJ build thread
My old ZJ build thread
Previous builds 99-XJ, 98-XJ, 89-XJ, 05-TJ, 95-ZJ, 79-J10
doogie is offline
post #3 of 22 Old 01-19-2009, 06:35 AM
ecdriver
I have a similiar setup and I'm just put on the KM2 33x10.50's. Love them! Plenty of fender clearance, no rubbing issues. Then again, I'm not trying to go over the Grand Tetons either. Tires are mounted on OEM Ravines with 5.5 backspacing. No pics as of yet, working on that today.
ecdriver is offline
post #4 of 22 Old 01-19-2009, 06:51 AM
emev0l
5 speed Manual.
33-10.50-15:
-51 LBS
-32.8-OD
32-11.50-15
-49 LBS
-31.8-OD
It depends on what you want to do with the Jeep, if your in the snow a lot taller narrower tires will be better, if your going to be in mud wider is always nice. I think the 33x10.5 are cheaper.
For what I would do with the Jeep, I would go with 33x10.5
Just remember the taller the tire the less acceleration you will have, not that your going to notice much between a 32 or a 33.
The 2 tires are very similar, it doesn't sound like your going to do anything crazy with the jeep, doesn't sound like your going do disconnect the front sway bar, If you do go with the 33's I would suggest getting longer bumpstops.
The last thing to think about, if you have stock wheels, you will probably rub with anything over 10.5" wide.
Either way, KM2s are good tires, nice choice.
emev0l is offline
post #5 of 22 Old 01-19-2009, 08:29 AM
bandit455
which tire would be better with 3.07's as far as driveability is concerned, I know neither would be ideal but a regear wont be in my budget for a while
bandit455 is offline
post #6 of 22 Old 01-19-2009, 08:49 AM
TheBoogieman
Disturbed!
TheBoogieman's Avatar
Probably not enough difference to matter but I would think 33x10.50's.
TheBoogieman is offline
post #7 of 22 Old 01-19-2009, 08:50 AM
bandit455
thats what i would think too because of less tread actually being in contact with the road
post #8 of 22 Old 01-19-2009, 09:12 AM
spokanistan
OP, you said in the past your Jeep was your DD correct? If so I will reccommend BFG AT K/O's instead of the KM2 all together. Yes I know it's not the question you asked but I thought I would toss it out there anyhow
Superman never made any money for saving the world from Solomon Grundy.
spokanistan is offline
post #9 of 22 Old 01-19-2009, 09:21 AM
rikkards
rikkards's Avatar
Can you elaborate on why you are recommending a different tire? Someone in the future may come across this thread and ask the same question.
rikkards is offline
post #10 of 22 Old 01-19-2009, 09:47 AM
spokanistan
The OP said "it is a daily driver and no serious offroad as in no flexing and no serious mud."
For the vast majority of people who say that, and even for those who wont admit it but it is the truth: an aggressive AT tire is a far better choice than an MT in my opinion. Better gas mileage, better on road handling, breaking, accelerating, etc, due to tread pattern, weight, composite material, etc. (edit to add: and it's cheaper)
Just like where I live you see just an amazing number of ridiculously lifted full size trucks with gigantic mud tires that seldom if ever actually go off road, some of them are work trucks and you cannot get them to understand that a lowered truck is actually easier to lift things in and out of so stock makes a good compromise
On Jeep forums here and elsewhere bigger/heavier/stronger is not always better though there is no real point arguing it... so I just thought I would mention it. The OP might actually need the latest greates most expensive MT there is, he may just want the look, I dunno but from his description of his actual need a BFG AT would be a better tire imho.
post #11 of 22 Old 01-19-2009, 09:50 AM
nascar2496
just a quick note, 3.07's suck. I have them in my jeep with 31x10.5 and it has no acceleration. i have to leave it in 4th gear on route 80 doing 70 or less to have any hope of maintaining speed.
My bro has 33x12.5 on his sport with 3.73's and its fine. he pulls on me going down route 80 in 5th gear and i cant touch him. his gas milage is better than mine cause he doenst have to be to hard on the throttle to accel or maintain speed.
Im NOT saying i race around but when its struggling to maintain speed there is something wrong there.
1996 Cherokee Sport
4.0l H.O. M5, 180k, 3in rough country, iron rock adj. Trac-bar, MT baja's 31x10.5, 3.55 gears.
nascar2496 is offline
post #12 of 22 Old 01-19-2009, 10:04 AM
bandit455
I kno my jeep came with 30's and 3.07's so it already sucks
post #13 of 22 Old 01-19-2009, 10:07 AM
b3nj4m1n
and your name is nascar? i don't believe you
"Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated, and Scorned. When his cause succeeds however,the timid join him, For then it costs nothing to be a Patriot." -Mark Twain
b3nj4m1n is offline
post #14 of 22 Old 01-19-2009, 11:07 AM
rikkards
rikkards's Avatar
Now that is a good answer
On a side note, (sorry for the threadjack) when I bought my Jeep, the PO had BFG ATs but they needed replacing and the dealer bought some Hercules MTs and replaced the 4 on the truck but left the spare as it had no tread wear. So I have 4 MTs and an AT.
The question I have is, if I ever have to use the spare, would it be an issue. The spare is the same size (31x10.5) but with the different tread pattern could there be problems?
rikkards is offline
post #15 of 22 Old 01-19-2009, 11:26 AM
spokanistan
Not enough to worry about it, imho of course. I mean I would only use the spare as a replacement until I could get into town and have my usual tire repaired or replaced but I would feel comfortable with it even taking my time down off a mountain - though shed hunting here with ice and snow I will surely wish I had a stud I will just go super slow.
I'm currently running studded/siped 33X9.5 M+S tires and my spare is my BFG AT in 33X10.5 (the other 4 awaiting spring) and while not the ideal set up I have no doubts it will get me out of the woods and back into town without damaging anything at all so long as I am not stupid on the skinny pedal
OP, my apologies again for all the thread drifting
Should I go 35s or 37s KM2s on my JK rubi axles? TX-WJ JK Wrangler Technical Forum 8 08-14-2009 04:21 PM
What PSI Do You Use For Highway With BFG KM2s? ElPaso2007 JK Wrangler Technical Forum 15 06-21-2009 12:13 AM
Wheel Sounds after getting 285/70/R17 KM2s & New Wheels ElPaso2007 JK Wrangler Technical Forum 18 06-19-2009 04:05 PM
New Meats!! KM2s!!! Apex Wrangler General Discussion 31 03-09-2009 05:13 PM
tire pressure for BFG KM2s 35's 2D BiGEN JK Wrangler Technical Forum 6 08-25-2008 05:32 PM
