Better RPMs for gas mileage? - Page 3 - JeepForum.com
post #31 of 59 Old 03-29-2010, 07:38 PM
13mx
So what would be ideal for my jeep? I have 32in tires, 3.73 gears and no heavy equipment. Should I be shifting gears right at 2k, or take it to the mid 2k?
13mx is offline
post #32 of 59 Old 03-29-2010, 08:00 PM
Imped
Imped's Avatar
Nobody can answer that for you. Just do what feels right. Either way, 2k is a little low IMO. 2.5-3k is where I USUALLY shift from 1-3 with great results. After that, you have enough momentum that 2k is fine.
OlllllllO
IndyORV
Imped is online now
post #33 of 59 Old 03-29-2010, 08:42 PM
JEK3
JEK3's Avatar
Try a tank one way, then a tank the other way. That's really the only way to figure out which will be better for you.
JEK3 is offline
post #34 of 59 Old 03-29-2010, 08:43 PM
Terrible2
Also when you compare make sure to take into consideration if you drove on hills and what not
Terrible2 is offline
post #35 of 59 Old 03-30-2010, 08:43 AM
jgorm
jgorm's Avatar
Exactly. Setups on smaller tires like yours are very different than larger tires. You are perfectly geared for 31's, which are quite a bit smaller than 35's. They weigh less, they are thinner, and the diameter is smaller. You can run 2000 RPM @ 65mph with no problems and good mileage. Step up to 35's and try to run 2000 RPM's at the same speed. It's a no go. Good mileage on 35's doesn't come until the mid 2k RPM range from my testing.
All the data was collected on my last jeep. 33's, 3.73s, and the 5 speed. It was in serious need of more gear.
jgorm is offline
post #36 of 59 Old 03-30-2010, 09:04 AM
kswyg001
2010 JK Wrangler
so how does all of this relate to the auto trans? i'm thinking that it doesnt relate at all and i'm getting into something deeper than i would really like to.
kswyg001 is offline
post #37 of 59 Old 03-30-2010, 11:34 AM
sxysouthtx
This is all sort of making sense to me. Being that my TJ is back in Texas and I'm in Germany I can't test the theories. I'm running 31X10.5X15's on a 4.0 running factory gears on a D35 in the rear. What's the best mileage you've had on 31's in what gear? Assuming you run 31's.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #38 of 59 Old 03-30-2010, 11:39 AM
dualtjs
2011 JK Wrangler
My TJ with 31's and 3.07 gears gets its best mpg at 1,800-2,000 rpm.
dualtjs is offline
post #39 of 59 Old 03-30-2010, 11:51 AM
Imped
Imped's Avatar
Factory gears means nothing. 3.07 or 3.73? You also didn't mention auto or manual. With 3.73, you're golden with 31's. With 3.07's, not so much. I hated that combination with a passion.
OlllllllO
IndyORV
Imped is online now
post #40 of 59 Old 03-30-2010, 12:02 PM
sxysouthtx
Not quite sure what I have as far as gears. But it's a 5 speed manual.
post #41 of 59 Old 03-30-2010, 12:06 PM
VanBCguy
When you get home from Germany, look at the 9 o'clock position of the rear diff. for a tag that says what gears you have.
Follow what this link says.
http://www.jeepforum.com/forum/f9/fa...-ratio-615380/
VanBCguy is offline
post #42 of 59 Old 03-30-2010, 12:08 PM
sxysouthtx
Appreciate it. I needed to know, and it was killing me.
post #43 of 59 Old 03-30-2010, 12:28 PM
Imped
Imped's Avatar
If 5th gear feels like it bogs down the engine, you probably have 3.07 gears. 3.73 gears will feel much more usable.
OlllllllO
IndyORV
Imped is online now
post #44 of 59 Old 03-30-2010, 12:35 PM
Melissas6570
What about 31's with an auto and 3.07 gears. That is what my friend has and it seems that the 3 speed auto helps with 3.07's.
Melissas6570 is offline
post #45 of 59 Old 03-30-2010, 12:41 PM
NE4X4
I didn't take the time to read all the responses, but one of the best ways to get the best milage possible is to have a vacuum gauge, and then drive to maintain the highest vacuum possible. Engine vacuum is basically measure the load the engine is under. When you minimize the load (hi vacuum) your milage will be optimized. You'll be amazed how just a little throttle will lower vacuum.
NE4X4 is offline
gas mileage
New 4.10s and RPMs h2osprt YJ Wrangler Technical Forum 2 12-28-2008 02:14 PM
RPMS won't go down? snakester14 TJ Wrangler Technical Forum 10 03-30-2008 04:31 PM
RPMs VanTheMan YJ Wrangler Technical Forum 5 03-28-2007 01:26 AM
Engine sputtering at low RPMs and loss of fuel mileage Scova TJ Wrangler Technical Forum 5 10-20-2006 04:59 AM
4.2L 258 RPMs.. Nine5YJ YJ Wrangler Technical Forum 3 05-02-2002 12:27 PM
