Which is a better lift kit for my 98 TJ - JeepForum.com
post #1 of 19 Old 08-04-2011, 07:58 AM Thread Starter
mracoker
I dont plan on getting bigger tires than 31/10.50, so I think a 2" lift will do fine. But I'm not sure which is a better kit.
Trail Master
Rough Country
The RC has some excellent instructions, which I like. I have changed out shocks before on my 95 Grand Cherokee, so I feel I can handle this with good instructions.
Thanks!
mracoker is offline
post #2 of 19 Old 08-04-2011, 08:18 AM
wwch99tj
The RC kit has new springs I would go with it to replace the 13 plus year old stockers. Just my opinion
Sent from my DROID2 GLOBAL using Jeep Forum
wwch99tj is offline
post #3 of 19 Old 08-04-2011, 08:20 AM
SaxManClay
RC all the way. Their new springs kick butt.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #4 of 19 Old 08-04-2011, 08:20 AM
thejafe
thejafe's Avatar
Have you considered the Old Man Emu kit?
thejafe is offline
post #5 of 19 Old 08-04-2011, 08:44 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
rc.
TheBoogieman is offline
post #6 of 19 Old 08-04-2011, 09:42 AM
rda616
Ome, or wish you had later!
rda616 is offline
post #7 of 19 Old 08-04-2011, 09:55 AM
Ross
Why not just do a 1 inch body lift? Not sure if you are new to jeeping or not, I am only assuming you are because you are new to positing here.. If you are new to jeeping there is a good chance you will find that 31 tires aren't enough. This will be especially true if you spend time on this board and wheel more than a couple times.
People will say I won't wheel it that hard, I don't need all that and then they get bit buy the bug. And it’s on from there.
I bought a 4X4 S10 just to get to fishing holes. I started having more fun getting to the fishing holes then fishing, that is when I got bit by the bug.
A 1" body lift is adequate for 31s, and they don't cost much money. If that is all the bigger you plan on going that will take care of your needs. If you go larger you can keep the 1" body lift and go from there. If you get a new lift kit only to find you want to go bigger you will end up spending more money then you needed.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #8 of 19 Old 08-04-2011, 10:22 AM
TheBoogieman
Over rated and over priced!
post #9 of 19 Old 08-04-2011, 10:33 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i'm sure thats why people remove their RC stuff a few months later and install OME or Currie...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 19 Old 08-04-2011, 11:34 AM Thread Starter
mracoker
I am new to this forum and jeeping. I have to say I am a huge fan of both!
Ross made some very good points, so now I am rethinking my approach. However if I do buy a kit I'll go RC.
Thanks for the insight!
mracoker is offline
post #11 of 19 Old 08-04-2011, 12:00 PM
csm41
OME is expensive, but you get what you pay for. I had an OME lift on my 2003 Rubicon and on my 89 YJ. Conversely, I had a BDS lift on a past Jeep (1999 TJ), and while not quite as good as the OME, it was still pretty damn well performing. I also think highly of the Zone/BDS line as a less expensive alternative to Currie or OME stuff. I also have a Zone on my current TJ. I can't comment on RC because I have no experience with that lift. Good luck!
csm41 is offline
post #12 of 19 Old 08-04-2011, 12:23 PM
rda616
Ome will last 4 times longer then rc and rides better then stock!
rda616 is offline
post #13 of 19 Old 08-04-2011, 12:37 PM
Xlr8n
1967 JK Wrangler
I've run both OME and BDS springs in my rig and agree there's not much discernable difference between the two. Haven't run the OME shocks, but if they are better than the BDS 5500's, I'd love to give them a try.
Xlr8n is offline
post #14 of 19 Old 08-04-2011, 04:22 PM
TheBoogieman
Opinions are like A holes and nobody wants to hear or see yours.
post #15 of 19 Old 08-04-2011, 04:24 PM
TheBoogieman
I'm guessing you've bought many RC lifts before moving on to foreign companies.
p.s. Do you still have that mountain goat problem?
lift kit advice
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
BL Body Lift install / Fan clutch / Motor Mount Lift sorta ... Mike_Motorbike TJ Wrangler Technical Forum 3 02-21-2011 12:33 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
