Bestop Underseat Lock Box + Fold/Slide Seats + Seat Risers?? - Page 2 - JeepForum.com
post #16 of 23 Old 10-04-2011, 07:28 AM
Tlflan
Originally Posted by TJe0454 View Post
so with a little help from my trusty sawzall i got the lock box installed! no seat risers or washers needed.
Just to be clear, can you tell us what box you used, if your seat is the fold and tumble type, and did you lose any functionality of the seat after the install? Does it still slide and fold and tumble (if it has that feature)?
Thanks
Tlflan is offline
post #17 of 23 Old 10-04-2011, 07:46 AM Thread Starter
TJe0454
its a fold and tumble seat. its the bestop underseat lock box not designed to work with that seat. i had lost the tumble functionality before doing the work so i didnt care.
TJe0454 is offline
post #18 of 23 Old 10-04-2011, 01:55 PM
roundlitefan
roundlitefan's Avatar
So I am guessing you just cut out the hump section of floor channel directly under where the lockbox mounts?
roundlitefan is offline
post #19 of 23 Old 10-04-2011, 02:58 PM Thread Starter
TJe0454
no, i cut the tabs for the tumble function, and the spring mount. no tub modification at all. i believe i made 3 cuts.
TJe0454 is offline
post #20 of 23 Old 10-04-2011, 03:11 PM
Best4x4
I have 97-02 sliders with Mastercraft seats mounted to them. The Bestop lock box bolted up after having to contort my hands into getting the front bolts started/tight (older sliders do not allow access to the front where you can gain easy access to the bolt head). Thought I was all good to go until I tried to slide the seat foward. The Bestop box is about 5mm to wide and hits the pivots that allow you to release the seat and slide it back/forth. I got it to slide, but it was like an act of congress and then I didn't trust that the seat was fully locked into place. IMHO not worth the trouble or safety risk, so out came the Bestop box.
Now on to round #2 I have my OEM 05 seats and sliders with a 1.5 riser kit. This WILL NOT work either as the tilt bar is still in the way of the box sliding back into place.
IMHO this is a very POORLY designed box. I liked the size of it, but Bestop needs to redesign it by being 5mm to 10mm shy in width and then 1/2 an inch shorter. I also think the lock should have some sort of rubber boot to cover it from the elements. That lock didn't work very smoothly out of the box and I can only imagine it with a little dirt/sand/mud in it!!!
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #21 of 23 Old 10-04-2011, 03:38 PM
athos76
I have the tilt forward seats, hockey puck seat lift, and one of these http://www.safeboxstore.com/safebox--portable-safe.html mounted under the driver's seat. I had to cut the tube that locks the tilt function together and bolt in a piece of angle to clear it. It fits a full size Glock and the face plate to my stereo at the same time
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #22 of 23 Old 12-10-2011, 04:27 PM
jammatime
i made mine at work, its kind of small but its bulletproof. Now i just have to wait till i get back from deployment to install it..lol I have the folding front seats, with seat risers.. got measurements so i know it will fit..
jammatime is offline
post #23 of 23 Old 12-10-2011, 04:49 PM
SBpunk
I just went with this guy
http://www.tuffyproducts.com/p-288-2...flip-seat.aspx
2004 Jeep WJ Overland
1992 Jeep MJ 4x4 5 speed
SBpunk is offline
bestop , do it yourself , lock box , seat mount
2 Dr JK - Seat won't fold & slide for rear passenger carnut08 JK Wrangler Technical Forum 34 05-28-2016 07:11 AM
Aftermarket seats + stock seat risers = :( sebastian22 YJ Wrangler Technical Forum 21 09-02-2013 03:25 AM
Putting a Bestop Underseat Storage Drawer Under the Rear Seat armyRN TJ Wrangler Technical Forum 6 12-27-2011 02:28 PM
Install, Jeep seats, Seat Risers and Kooler Konsole SavageSun4x4 TJ Wrangler Technical Forum 6 09-14-2007 11:37 AM
Does your driver seat fold and slide? bmboll TJ Wrangler Technical Forum 36 11-30-2006 12:14 AM
