Bestop Trailmax aqua seat install - JeepForum.com
post #1 of 10 Old 05-02-2007, 06:46 PM Thread Starter
barry1me
barry1me's Avatar
I got my seats the other day. I ended up going with the Bestop Trailmax Aqua series. I ended up going with the Black denim color. I wasnt sure which seat I wanted to pick, but then I called Bestop and spoke to them about there seats and I was sold. The aqua series seemed to make sense for me due to there ability to be able to handle the elements. They came well packaged, no way for them to be damaged during shipping. You have to order the correct brackets for whichever vehicle you have. The only challenge I had was removing the factory seats. The bolts can be a pain to get to, but are doable.
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #2 of 10 Old 05-02-2007, 06:51 PM Thread Starter
barry1me
barry1me's Avatar
First thing I did was remove the front seats. The Drivers side seat was wore pretty bad, that was the main reason for upgrading. I left the risers attached to the tub. It was a little harder to get to the bolts, but less work in the end. After I removed the seats I attached the brackets to the Bestop seats. They bolts on with no problems. All of the hardware was a perfect fit, and well designed.
Sport TJ build
barry1me is offline
post #3 of 10 Old 05-02-2007, 06:58 PM Thread Starter
barry1me
barry1me's Avatar
I installed the seats back on the factory risers. NOTE: make sure that you install the recliner knob on the correct side of the seat for which seat your installing. I did this wrong on the first seat. They bolted up like the OE seats to the risers. They fit perfect. I was quite impressed, Bestop spent some time designing these. The one thing I was a little worried about was the seat height, but that wasnt even an issue.
Sport TJ build
barry1me is offline
post #4 of 10 Old 05-02-2007, 07:05 PM Thread Starter
barry1me
barry1me's Avatar
now that I had the Front seats installed I started checking the fittment and functionality. The one thing that concerned me was the passenger side seat and how the Bestop seat would function on the factory riser. The only thing you have to do now is to push the lever down on the bottom of the factory seat bracket, and turn the recliner clockwise to rotate the seat back forward. When the seat slid forward and down, the Bestop seat doesnt make any contact with the dash or anything else.
Sport TJ build
barry1me is offline
post #5 of 10 Old 05-02-2007, 07:18 PM Thread Starter
barry1me
barry1me's Avatar
now for the rear seat. I choose the same seat as the fronts. The bestop trailmax aqua seat for the fold and tumble. This was about as easy as airing up your tires. If you already have a fold and tumble rear seat, then this will fit in with no problem. It uses the OE hardware. It comes with with all the hardware you need if you dont have a seat to bolt into your tub. Everything is all adjustable to make sure the fittment is perfect.
Sport TJ build
barry1me is offline
post #6 of 10 Old 09-26-2007, 07:52 AM
WranglerTim
How much effort is it to fold the front passenger seat forward to its maximum position? I'm thinking about picking up a set of these seats, but I drive my daugher to daycare every day. The passenger seat has to be all the way forward for me to fit her car seat in. Is it going to drive me bonkers rotating the reliner knob every day?
WranglerTim is offline
post #7 of 10 Old 09-26-2007, 08:23 AM
shaggy105
Looks pretty good. My driver side seat if just like yours so I've been thinking about some new seats. Where did you buy them from?? How do you like them so far??
RED JEEP CLUB MEMBER 413
4.0L Auto
D Cepek DC-1 Rims w/ 33x12.5 Wrangler MT/R's w/ Kevlar
Rusty's front and rear bumpers
Poison spider rockers
shaggy105 is offline
post #8 of 10 Old 09-26-2007, 08:50 AM Thread Starter
barry1me
barry1me's Avatar
I like them a lot. Very pleased so far. You can buy them from several vendors but I believe Quadratec had the best prices. PM sent
Sport TJ build
barry1me is offline
post #9 of 10 Old 09-26-2007, 09:11 AM
Metzgerhund
Metzgerhund's Avatar
Very nice! I had thought about these seats as well, but went with Legacy seat covers because of the cost factor and the other goodies I had on my wish list. With the info you provided about these I will definetly be going with these once my covers are worn out.
Metzgerhund is offline
post #10 of 10 Old 07-04-2008, 12:32 PM
krawler510
Hey man, I know you posted this a while ago but what material are those seats?
And also how tight do they fit against the center console? I have a Tuffy one and the stock seats rub it pretty hard and I'm worried new ones might not fit well.
Thanks a lot. Sweet avatar.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
Which Seat Bestop Trailmax II Sport or Corbeau Moab? thord Wrangler General Discussion 1 12-10-2009 10:00 AM
Trailmax II Rear Seat by Bestop Fitment Question jeepwave TJ Wrangler Technical Forum 6 07-17-2009 05:40 AM
Ya gotta bekidding me Bestop Trailmax 2 rear seat prob Floridazed YJ Wrangler Technical Forum 7 06-05-2009 12:07 PM
Anyone running Bestop Trailmax seats with a seat cover? Jerry Bransford TJ Wrangler Technical Forum 2 05-05-2009 07:31 PM
Bestop Aqua Sport Seat trips TJ Wrangler Technical Forum 2 03-27-2007 10:16 AM
