Bestop Supertop ... will a half door top fit on my full door TJ? - JeepForum.com
post #1 of 9 Old 07-12-2010, 09:52 PM Thread Starter
AWILD
AWILD's Avatar
Title says it all....
I have a factory TJ soft top with full doors.
Found a bestop supertop w/ all hardware but was from a half door... will it fit no problem?
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline
post #2 of 9 Old 07-12-2010, 10:55 PM
sahara_tj
It should. I have one TJ with full doors and one with half doors, and the tops are interchangeable. I say do it.
Function over Form
Built Not Bought #435
sahara_tj is offline
post #3 of 9 Old 07-12-2010, 11:01 PM Thread Starter
AWILD
AWILD's Avatar
and this is a supertop on supertop hardware right?
TJ
AWILD is offline
post #4 of 9 Old 07-12-2010, 11:07 PM
sahara_tj
If it has all the hardware it shouldn't be a problem. I bought the supertop with no hardware and just re-used my factory hardware, and it was a perfect fit replacement.
Function over Form
post #5 of 9 Old 07-12-2010, 11:16 PM Thread Starter
AWILD
AWILD's Avatar
To clarify anyone misreading that in the future...a supertop will NOT fit oem/factory hardware. They are completely different style tops with completely different style hardware. It would be like trying to put a YJ soft top on a TJ.
...but I think I get what you were getting at. You owned both style door Jeeps, but only one supertop and it fit either one the same.
TJ
AWILD is offline
post #6 of 9 Old 07-12-2010, 11:26 PM
sahara_tj
My bad, i just reviewed the invoice from when I ordered it, and I got the replace-a-top, not the supertop. that's why it worked with the factory hardware. sorry for the misunderstanding. If you did get the supertop with all matching hardware, I don't see why it wouldn't work though.
Function over Form
post #7 of 9 Old 07-13-2010, 08:23 AM
BestopTeam
Vendor
BestopTeam's Avatar
2010 JK Wrangler
The Supertop with upper doors is the same as the Supertop without doors - the doors are just an option for those who need them.
The Replace-A-top is exactly the same way- available with or without doors, but the actual top itself is the same.
On TJs and JKs you can swap doors back and forth easily at any time with any top.
YJ's can be a bit more complicated.
BestopTeam is offline
post #8 of 9 Old 07-13-2010, 11:06 AM Thread Starter
AWILD
AWILD's Avatar
Ah, finally figured it out. Thanks. To clarify anyone reading in the future, the supertop skin and frame are only made in one model, yet the part # changes if you select the "soft doors" option because it includes the actual soft door.
TJ
AWILD is offline
post #9 of 9 Old 07-13-2010, 11:35 AM
Jason D
I would advise against getting a Supertop. They suck compared to the factory TJ top.
2006 Jeep Wrangler Rubicon
Jason D is offline
tj , wrangler , bestop , supertop , fit , fitting
full door hinges on half door? obsessedjeeper YJ Wrangler Technical Forum 0 02-17-2010 05:04 PM
Questions about Half Door and Full Door Locking Mechanisms... atticus_ar TJ Wrangler Technical Forum 8 12-04-2009 02:26 PM
bestop supertop/full door issues... greta TJ Wrangler Technical Forum 16 05-18-2009 09:13 AM
Half door mirrors on a 92 full door? JFranko YJ Wrangler Technical Forum 2 10-25-2008 07:10 PM
Half door mirror on full steel door? Shinner YJ Wrangler Technical Forum 5 11-02-2005 03:03 PM
