Bestop Softop rear window removal - JeepForum.com
post #1 of 12 Old 07-17-2010, 10:33 AM Thread Starter
jmiera
So i have a question...Does anyone know how to take out the back window of the softop...thanks im having a brain fart
jmiera is offline
post #2 of 12 Old 07-17-2010, 10:59 AM
JCWJEEP
2010 JK Wrangler
Unzip it from right to left, pull the zipper off of the track at the bottom left corner. Pull the bottom of the window, straight out from the body of the vehicle to remove the tailgate bar out of the brackets. The window should now be completely free of the vehicle. Now you can either remove the tailgate bar by sliding it to the side or you can leave it in.
JC Whitney Jeep Team
JCWJEEP is offline
post #3 of 12 Old 07-17-2010, 11:54 AM Thread Starter
jmiera
cool thanks man...is it the same process putting it back on ? ...seems like would be a headache...i will try it here shortly and let you know my results
jmiera is offline
post #4 of 12 Old 07-17-2010, 11:56 AM Thread Starter
jmiera
also it has 2 zippers...
jmiera is offline
post #5 of 12 Old 07-17-2010, 12:19 PM
nikeo02
Mine has 3 zippers. Two up each side, and one on the top.
nikeo02 is offline
post #6 of 12 Old 07-17-2010, 12:35 PM
Lastshot
They both stay on the softop itself, but you can pull away the window.
The reason for 2 zippers is so you can unzip both sides to the top, and then roll up the rear window. There is 2 straps on the softop that hold the rolled up window on.
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #7 of 12 Old 07-17-2010, 07:15 PM Thread Starter
jmiera
last shot.... i got that.....but i want to tke out the window completely..there doesnt seem to be a way to do it
jmiera is offline
post #8 of 12 Old 07-17-2010, 07:29 PM
nikeo02
If it is a bestop, you unzip the 3 zippers completely, and it comes out! Thats it. Its not a complicated part.
nikeo02 is offline
post #9 of 12 Old 07-17-2010, 08:14 PM Thread Starter
jmiera
its a bestop but there is only 2 zippers ...again TWO (2) zippers !!
jmiera is offline
post #10 of 12 Old 07-18-2010, 03:42 AM
TeeJay00
Show us a picture of it !!!
TeeJay00 is offline
post #11 of 12 Old 07-18-2010, 07:05 AM
JerseyDoug
Can I go home now?
Yes........
JerseyDoug is offline
post #12 of 12 Old 07-18-2010, 07:12 AM
JerseyDoug
Can I go home now?
We got it. Two zippers. One zipper track. Pull the right-most zipper along the zipper track until it meets the left-most zipper at the bottom left corner of the window. Then, hold down both zippers with your left hand while pulling the zipper track out of the zippers with your right.
bestop , rear , removal , remove , removing , soft top , softtop
Softop Rear Window ..... HELP ! Skeezer TJ Wrangler Technical Forum 6 03-08-2010 09:29 PM
Soft top Rear Window - Stock vs Bestop rpeatman TJ Wrangler Technical Forum 1 05-03-2009 06:32 PM
Rear Right Softop Window IIIIIlllllIlI TJ Wrangler Technical Forum 8 01-16-2008 08:35 PM
replacing softop rear window uconnjl TJ Wrangler Technical Forum 5 03-07-2005 09:33 AM
Softop rear window questions JohnW63 YJ Wrangler Technical Forum 3 12-07-2004 06:25 PM
