bestop black twill top? - Page 2 - JeepForum.com
post #16 of 36 Old 04-16-2013, 09:28 PM
Icarus
Ugh, the twill tops are literally 2x the price of a regular Supertop NX up here
Ϣr
Icarus is offline
post #17 of 36 Old 09-29-2013, 08:06 AM
lapremidi
2010 JK Wrangler
The twill top I just got for my 2010 WRANGLER was $1,500.00 and worth every single cent. Far superior in quality to any others I have seen.
lapremidi is offline
post #18 of 36 Old 06-17-2014, 10:56 AM
Summergirlbeach
Black twill best top
Love this top! So much better than the sail top.... I found it $150.00 cheaper on amazon then most sites. The top is so soft and folds way easier than my old sail. The only thing I have to get used to is the wind tunnel noise when I get it up to 60 mph and higher. So I just turn up the radio loud.
Summergirlbeach is offline
post #19 of 36 Old 06-17-2014, 03:59 PM
rjdriver
I picked up a twill Trek NX and I really like it, I just wish that Bestop would make soft uppers to match.
From the land of Ice and Snow where we have 8 months of winter and 4 months of bad sledding
rjdriver is offline
post #20 of 36 Old 06-18-2014, 07:16 AM
rouxbicon
x2,
and other colors would be nice too, like Dark Khaki...not a big fan of black tops, no offense to those that have 'em...
'03 red Rubi
rouxbicon is offline
post #21 of 36 Old 06-19-2014, 02:42 AM
Icarus
I ended up buying a Twill Supertop NX cover due to the amazing deal I got (about $250 or so more at the time, not seen a price close to this since,) and the much better warranty.
It didn't take them long to come out with other Twill tops, so hopefully they will follow suit with the uppers
Ϣr
Icarus is offline
post #22 of 36 Old 06-19-2014, 09:39 PM
jeepwrangler97
Wind tunnel noise? Could you elaborate? Isn't it quieter than the sailcloth?
Sent from AutoGuide.com Free App
jeepwrangler97 is offline
post #23 of 36 Old 06-19-2014, 09:44 PM
Icarus
I think it may be partly from not running the support cross-arc up front? I get a 'wind tunnel' noise when I have the top all up and windows on side+rear and full doors on, but crack the window on one side an inch or so. Doesn't do it any other time so far. Just need to open the window another inch or tow and it goes away...
Ϣr
Icarus is offline
post #24 of 36 Old 06-19-2014, 10:28 PM
Robert J. yates
You do not have the crossbar for the rear window assembled correctly. It's creating an air gap which is what is making your top noisy. I have a twill top and it is as quiet as a hard top.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #25 of 36 Old 06-19-2014, 10:54 PM
Icarus
No, I'm talking about the front arc that is removable. I've never used it so don't know if it makes a difference... I do have the rest together correctly though...
Ϣr
Icarus is offline
post #26 of 36 Old 06-19-2014, 11:25 PM
Robert J. yates
I do not have a front support nor roll bar pads so my install could be one considered to have considerable slack. If you have to roll down your windows to balance out the pressure, you have something wrong. Alternatively, you also need to realize that you need your vents, defroster or ac on along with the fan to inflate the top.
post #27 of 36 Old 06-20-2014, 02:30 PM
Icarus
Maybe if it's cranked on high, but I really don't think it will make a difference and even then very little if so...
I spent way too much time making sure it was installed right, watched Bestops and other videos and all etc It doesn't do it with the windows up all the way, just when drivers side cracked an inch or two, and top all buttoned up as I mentioned, then down past that it doesn't...
I'll muck around with the fan and different things and see if it makes any difference...
Ϣr
Icarus is offline
post #28 of 36 Old 06-20-2014, 02:44 PM
bbradUSMC
Wonder if they will come out with this for the Trek Top NX?
bbradUSMC is offline
post #29 of 36 Old 06-20-2014, 03:33 PM
jeepwrangler97
They make one already
post #30 of 36 Old 06-20-2014, 05:19 PM
BadJohnny
I just switched to a Trektop NX from a rampage top. The center bow does make a difference.
To the OP; as far as Twill goes I would only consider it if the price was a lot lower. Even then I believe the sailcloth is a better choice for a off-road or recreational vehicle. If I park under or near trees and some tree sap falls on it it's not that bad to clean up the sailcloth vs twill, just as a example.
The Trektop NX fits snug and seals up tight. I have the black diamond type and it's as quiet or quieter than OEM. The front header fits as good as original equipment.
The rear strap buckles are the only real area they could improve on. The straps will not stay tight without a bit of ingenuity. I just popped a small hole in the free running end and secured that end once tight with some 550 cord. Only needed to worry about this when in bikini top mode.
@ rouxbicon I'm a fan of the Dark Khaki too. I went with black though at the time I couldn't find Dark Khaki.
BadJohnny is offline
bestop , soft top , twill
