best way to fix exhaust leak without welding? quick dirty fix - JeepForum.com
post #1 of 13 Old 10-06-2009, 05:45 PM Thread Starter
abadjay
hey guys I need some advice for patching an exhaust leak without welding. To make a long story short my exhaust severed right before my cat because the previous owner decided to ghetto rig a new cat on. so now I need to ghetto rig ghetto rigging... ugh...
anyway i managed to track down an adapter to put the exhaust back together. when all said and done there is a small, but noticeable leak. not a big deal for my standards and this quick dirty fix, but It wont pass inspection/emissions.
I need a cheap dirty fix. I would love to do this the right way but Im unemployed right now and money is tight. I plan to get a whole new downpipe when I get a job. (mine is pretty rusted, it will probably be shot in a year) Iv tried JB Weld on exhausts before and it never holds more then a day, is there any decent product out there that I could slap on there and have it hold for at least a few months?
By the way before anyone says bring it to an exhaust place to weld it for 20 bucks, I wish I could but your not going to be able to weld where this leak is (top of pipe inside the cross-member.)
Thanks in advance!
1997 Jeep wrangler sport
4.0L
Uban off roading in Pittsburgh, Pa!
abadjay is offline
post #2 of 13 Old 10-08-2009, 01:13 PM Thread Starter
abadjay
so by the lack of replies Im guessing nobody has had any good luck with patching a leaky exhaust. A friend suggested furnace cement. Im going to give that a try and if I have good results Ill post it for other people possibly looking for a quick temp fix.
4.0L
abadjay is offline
post #3 of 13 Old 10-08-2009, 01:16 PM
93jeepyj
Auto parts stores sell an exhaust patch kit for around 10 bucks thats basicly some kind of heat tape and probably something very similar to the furnace cement. I'd weld it up for you if you were closer, also ive had midas weld an exhaust doing the same thing on a junk car I had years before I started welding, the guy did it for 20 bucks cash I think and it was in it out in 10 mins.
93jeepyj is offline
post #4 of 13 Old 10-08-2009, 01:16 PM
NotURMailman
Is it leaking from a clamped together joint?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #5 of 13 Old 10-08-2009, 01:47 PM
mudb8
want it rite or rite now?
mudb8's Avatar
band clamp
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #6 of 13 Old 10-08-2009, 01:52 PM
B2CARPEN
Get some exhaust cement at your local auto parts store. Apply it around the areas with leaks and it will harden up and seal it up. Just make sure to get it off your fingers right away before it dries.
Founder of
B2CARPEN is offline
post #7 of 13 Old 10-08-2009, 02:07 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yea, you can buy this wrap stuff with some kind of epoxy/cement in it. I tried it once, never worked...just fell off and was a mess to work with. you might be able to make it work in a pinch.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 13 Old 10-08-2009, 02:12 PM
X-tacy
Exhaust bandages. Very inexpensive and just require you to wrap it like you would wrap an ankle. All of the wraps I've seen are white wrap, but if you don't care about the color... that is your best bet.
Most discount auto parts stores will carry it.
-Chris
ATL GA to Boulder CO Journey Write-Up Here: http://jeepforum.com/forum/showthread.php?t=813407
X-tacy is offline
post #9 of 13 Old 10-08-2009, 02:12 PM
B2CARPEN
And it looks like complete **** as well... but worked for me.
Founder of
B2CARPEN is offline
post #10 of 13 Old 10-08-2009, 03:26 PM
Max-Q
1983 CJ7
I had the same problem you are having. My exhaust was rotted out just before the cat and nobody could weld it because the skid plate was in the way. I used a 2-3 inch band clamp to cover it until I could afford a complete exhaust. It worked fine and I even passed the state safety and emissions inspections with the band in place.
I think I bought it from AutoZone.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #11 of 13 Old 12-31-2013, 01:49 PM
xxxxxxxxxxxxxxxBrutus1983
Guest
1977 CJ7
Another exhaust leak...
Ok, I've isolated my leak at the manifold. There's a small crack right where they bolt onto the block. What can I use to stop this leak without taking the manifold off? It's a 258 ci with the manifold bolted onto the driver side of the block.
Any help would be appreciated.
xxxxxxxxxxxxxxxBrutus1983 is offline
post #12 of 13 Old 12-31-2013, 02:16 PM
jay-h
There's a better thing than the bandages (which don't last long) available from some parts stores. It's basically thin stainless sheet which you wrap several turns around the pipe and clamp. Only works on straight sections of pipe though.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #13 of 13 Old 12-31-2013, 02:24 PM
jay-h
That's a tough one. There is a steel filled high temperature compound that I've used to seal small leaks but I doubt you'll be able to do it with the manifold in place.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
Quick 8.8 welding question Poke YJ Wrangler Technical Forum 5 01-09-2010 07:04 PM
New YJ - Project quick, light, and dirty frumpy YJ Wrangler Technical Forum 25 07-21-2008 05:48 PM
Tranny swap - Quick and dirty ZonaWrangler YJ Wrangler Technical Forum 0 02-14-2008 01:03 AM
Dirty intake and exhaust ports bigstinger YJ Wrangler Technical Forum 2 06-27-2006 08:23 AM
Exhaust Welding Inukshuk YJ Wrangler Technical Forum 14 08-25-2004 07:52 AM
