Quantcast best way to bleed power steering??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > best way to bleed power steering???
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 11-18-2008, 10:33 PM   #1
freshlikefruit
i just installed a durango box in my tj, which was aweful as i live in MI and had to do it alone in the dark, but how do i go about bleeding it?
97 tj- work in progress...
Thanks to all who take the time to help transform jeep newbs into self-sufficient jeep-a-holics
freshlikefruit is offline   Reply With Quote
Old 11-18-2008, 10:35 PM   #2
RVA_TJ06
Fill with fluid... crank it up, turn it lock to lock until the air is out.
Finally paid off...
RVA_TJ06 is offline   Reply With Quote
Old 11-18-2008, 10:36 PM   #3
freshlikefruit
it wont hurt anything with the motor running? do i leave the cap off?
Old 11-18-2008, 10:39 PM   #4
RVA_TJ06
well you don't really need it running.. you could just turn it lock to lock.. i leave the cap off... just to add more fluid.
Finally paid off...
Old 11-18-2008, 10:42 PM   #5
freshlikefruit
ok, ill give er a shot. i was doing this earlier, i suppose it takes a while to get all the air out of the system then?
Old 11-18-2008, 10:47 PM   #6
RVA_TJ06
It shouldn't take too long.
Finally paid off...
Old 11-18-2008, 10:49 PM   #7
freshlikefruit
thanks, good to know
Old 11-19-2008, 10:24 AM   #8
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Your first initial bleeding of steering pump should be without engine running!Lock to lock at least 30 times. This will allow fluid to start lubricating pump after so you can start an continue rotating until all air has been purged from system! Oh yea forgot to mention like Jerry said... Have tires lifted of ground when doing the bleeding!
GOLENJEEPTJ is offline   Reply With Quote
Old 11-19-2008, 10:38 AM   #9
bucks11
Mine is constantly bled through the mysterious leak in it...
I've heard 25 lock to lock will get all air out and fluid in, but i'd take the advice on the 30, just for safe measure...
1999 TJ
bucks11 is offline   Reply With Quote
Old 11-19-2008, 10:44 AM   #10
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Do NOT (!!) start the engine for the initial bleeding!! Doing so will cause cavitation inside the power steering pump and damage the pump vanes. Jack up the front-end so the weight is off the front tires and without the engine running, turn the steering wheel back and forth (lock to lock) at least 25-30 times. Once that is completed and you have topped off the power steering fluid reservoir, then you can start the engine and drive it. Stop after a short while and check the fluid level and add more fluid if needed and you're done.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 11-23-2008, 09:28 PM   #11
freshlikefruit
thank god i didnt listen to RVA TJ06, i looked it up on Stu's site...now i have a leak though from the lower end of the lines where they thread into the pump. I believe there is an o-ring kit available, any truth to this?
Old 02-27-2011, 02:50 AM   #12
Boodyrider
There may be a teflon washer that is one time use on the pressure hose fitting. It should be replaced EVERY time the fitting is removed. (It comes with new pumps) If not that, it'll be an o-ring.
if your line had some white plastic looking stuff that fell off when the old pump was removed... it's the teflon 'washer' style.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Glock Forum
