Best Top Super top info - JeepForum.com
post #1 of 5 Old 08-04-2010, 06:28 PM Thread Starter
JJeeper09
I am about to get a used best top super top and the guy told me you do not need the door inserts like the oem top. is this true? and does anyone have pictures of how it is mounted the the doors
JJeeper09 is offline
post #2 of 5 Old 08-04-2010, 06:38 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
The OEM surrounds are not used with the Supertop.
They have instructions on the Bestop website that are pretty detailed for installing them if you have questions.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #3 of 5 Old 08-04-2010, 07:44 PM
97yellow
i have the best super top with hard doors and there are rods (part of the tops frame) that go from the body to a supplied bracket that mounts where the roll bar mounts to the windshield, and the top wraps around the rod and secures with sewn in velcro. works good. very happy with it.
97yellow is offline
post #4 of 5 Old 08-04-2010, 07:46 PM
dougiefresh131
i have a supertop. all of the instructions are on the website if you are curious. Its pretty simple and straightforward to set up etc. a little water gets in around the doors, but its no big deal. i'd say its less water than with my hardtop. no need for door surrounds.
dougiefresh131 is offline
post #5 of 5 Old 08-04-2010, 08:06 PM Thread Starter
JJeeper09
Is 350 for a used one a good deal?
bestop , super top , tj , wrangler , door surrounds
Anyone have info on supercharging a 2.5 with a 3.8 Super Coupe setup? qk99Cobra TJ Wrangler Technical Forum 10 03-17-2011 05:35 PM
Anyone with a 3.5" Super Flex and Super Swamper 33s? Danegerous TJ Wrangler Technical Forum 1 03-14-2009 10:49 PM
Flowmaster super 40 vs super 44 vs Cherry bomb extreme wolfstyle TJ Wrangler Technical Forum 4 04-22-2008 01:00 PM
RE 4.5 super flex info needed jugg TJ Wrangler Technical Forum 10 12-03-2006 11:08 PM
Door Removal question, super quick, super easy....only will take a sec... MCTampa YJ Wrangler Technical Forum 17 07-18-2006 01:42 PM
