best tj lift? - JeepForum.com
post #1 of 12 Old 05-30-2010, 11:00 PM Thread Starter
weasel796
best tj lift?
I am considering either the pro comp TJ 4" stage II kit from 4wheelparts.com or the Rubicon Express 4.5" superflex kit. The guy I talked to at the store recommended the pro comp kit because he thought it would be more durable/reliable and cheaper than the RE. I want to know what kit people recommend. I am looking for a lift kit that will easily fit 33" tires and have a lot of flex to it. I don't want it to require a lot of maintenance ( I hear Rubicon express can require frequent bushing replacements.) I want to keep it around $1500-2000 for the kit with all the parts I need if possible *springs, shocks, SYE, ect.* any advice?
weasel796 is offline
post #2 of 12 Old 05-30-2010, 11:13 PM
jmartin2nd
2015 JK Wrangler
I run a Rock Krawler short arm 4" flex system and have had little maintance on it just need to make sure the jam nuts r tight. but as for pro comp vs RE i would get the RE which is a better setup and more flexible, adjustable arms makes a big difference in alignment and pinion angles also. one big thing is u get what u pay for, Im not saying the Pro Comp kit is bad. those r my couple pennies
jmartin2nd is offline
post #3 of 12 Old 05-30-2010, 11:29 PM
bhall687
I have been researching the same questions for a while. I was looking at the PC and everyone said that it is not that great of a lift. The control arms are not great quality from my understanding. The RE lift you will more than likely have to replace the bushings quite a bit as they have an hourglass mount and the bushings seem to fail alot from what people say. I have narrowed it down to the currie lift which there are not really any cons for. The CA's are all adjustable and have johnny joints on both ends. These are very durable if greased and maintained properly. It seems that this kit maybe just above your budget you mentioned, but everyone says you will not regret it and it will be done right the first time. That is what I have learned.
bhall687 is offline
post #4 of 12 Old 05-30-2010, 11:32 PM
remery829
Let me google that for you
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #5 of 12 Old 05-30-2010, 11:41 PM Thread Starter
weasel796
are there any recommended places to buy this from? and what is the price range? I am goggling it, and starting to research it, but I figured I would ask here if there is any recommendations that may not come up on the top of a Google search.
post #6 of 12 Old 05-30-2010, 11:52 PM
DezertTJ
i have the pro comp lift on my rubi. it rides alright. not the best flex but the bushings haven't been a problem. moving to full traction 4" springs cause my rear is sagging. but go with RE, full traction, currie, or make your own
DezertTJ is offline
post #7 of 12 Old 05-31-2010, 12:01 AM
Boreal
Boreal's Avatar
I have the 4.5" superflex kit but swapped out for 3.5" springs. It's a great kit and very complete if you pay the few extra bucks for adjustable control arms (lowers) all around. I added OME shocks to it and it has been sweet. My only complaint so far is with the quick disconnects... driver's side sheared when I was in Moab the other weekend (it wasn't disconnected at the time) and I wasn't even doing anything gnarly
I bought from 4x4groupbuy.com. I looked all over the place and they had the best price.
Boreal is offline
post #8 of 12 Old 05-31-2010, 04:36 AM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
I did the same thing (RE 4.5" superflex with 3.5" springs) but with the RE shocks also from 4x4groupbuy after shopping around. I'm happy with it. It also came with an AA SYE kit (Advance Adaptors [a well respected brand name] Slip Yoke Eliminator) and a Tom Wood's rear CV driveshaft. The RE 3.5 lift give you at least 4" of lift. A very complete kit that if priced out separately would have been a lot more expensive. I sold the sway-bar disconnects that came with it and put on a Currie Anti-Rock set-up. When looking at kits in the 3" and higher lift, make sure they include things like an adjustable front track bar, bracket for the rear track bar (you might end up having to buy an adjustable rear track bar anyway like I did), adjustable upper control arms (at least for the rear) if you're going to do the SYE/CV rear driveshaft route (as opposed to spacing down the skidplate), longer brake lines, extended bump stops, etc. If they don't include them, factor their cost into the "budget" kit(s) you might be looking at.
For example, for an AA SYE and a TW rear CV driveshaft, figure another $465.00 into your cost Advance Adapters Slip Yoke Eliminator Kit + TW Drive Shaft when looking at lift kits that include it (the RE kit below) vs. most others that don't include it in the cost of their lift kits.
Here's the RE 3.5" superflex kit from 4x4groupbuy (mentioned above) with SYE, rear CV driveshaft, front track bar, extended brake lines, shocks, adjustable upper control arms/new fixed length lower control arms, etc. for $1835.00 at Rubicon Express RE7000-3 3.5 Super-Flex Kit & SYE Combo and Shoc They sell the same kit but without shocks for less, and then maybe you could get cheaper shocks to bring the price down a bit. You (the OP) asked, and this is my recommendation. And I looked at other options (Black Diamond, Rustys, etc.) before getting this kit, and while others started out cheaper, their final cost grew once you started adding extras that the RE kit here included. Of course, only you can decide if these "extra's" are things you feel you want or need. Some people are happy with just four springs and shocks and lowering the skid plate.
Help I'm typing and I can't stop! I have to let it go...
So I would start at 4x4groupbuy.com and check their prices and what comes with their kits (especially their RE kits), and then compare to Pro-Comp or whoever you want to check out and compare with what comes in their kits (make sure you're comparing apples to apples). Let us know what you find and decide on.
armyRN is offline
post #9 of 12 Old 05-31-2010, 05:39 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Procomp is complete crap. Some say their springs are ok, but I've heard they sag pretty bad. The guy at 4-wheel parts is a tool and is recommending procomp because they're the same company. Rubicon Express bushings won't last 3 months.
If you want the BEST kit, as indicated by your title, then look at Clayton Off-Road or Currie.
Clayton Off Road - Jeep Lift Kits - Jeep Cherokee Lift Kits - Jeep Wrangler Lift Kits - Jeep Suspension Lift Kits
Currie Enterprises - Custom Rearends, Jeep/Off-road Parts, Crate Rearends, 4x4 Rearends
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 12 Old 05-31-2010, 06:20 AM
armyRN
armyRN's Avatar
To quote the OP: "I want to keep it around $1500-2000 for the kit with all the parts I need if possible *springs, shocks, SYE, etc.* any advice?"
While I'm sure the Clayton and Currie kits are top notch quality products, they're also $1775 to almost $2000 before adding the cost of shocks, SYE, rear driveshaft, etc. So add another $700 (plus/minus) or so for these in addition to the price of the Clayton or Currie kits for what already comes in the RE kits from 4x4groupbuy.
I think the OP was looking for the best complete lift kit within his budget of $1500 - 2000. And yes, we all know about the RE bushings issues. I haven't had to replace mine... yet.
armyRN is offline
post #11 of 12 Old 05-31-2010, 06:50 AM
RubiconRazorbac
RubiconRazorbac's Avatar
Do yourself a favor and call Gerald at Savvy Offroad, or PM him on here (username is "Savvy"). See what he can do for you.
You'll be pleasantly surprised. At least get the information before you buy
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #12 of 12 Old 05-31-2010, 06:55 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
you can also piece the currie together.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 10:03 PM
