best synthetic differential oil ??? - JeepForum.com
post #1 of 138 Old 12-13-2008, 04:55 PM Thread Starter
drumkite2
I'm getting ready to change the front and rear diff oil to synthetic, and was wondering which is the best for an 06 Rubicon? Also have an 02 sport with Dan 44 rear 3.73s. Would this need the same as the Rubicon? Do these diffs use gaskets, o-rings, or RTV?
drumkite2 is offline
post #2 of 138 Old 12-13-2008, 06:15 PM
Sahara01
Amsoil Severe Gear. They make 3 weights. For your application, 75-90 for normal service in both rears. If you tow, 75-140 in you back axle.
You can use RTV, or gaskets. I personally like the Lubelocker gaskets, just make sure you follow their instructions for torque of the bolts that hold the cover on, use a little Blue (medium strength) Locktite on each bolt. That will prevent the bolts from loosening and the cover from leaking.
Shortbus Offroad Team #242
sponsored by
, GOODYEAR TIRES,
, Solid Axle Industries, Genright,
Sahara01 is offline
post #3 of 138 Old 12-13-2008, 07:02 PM
'B'wigstrailrig
I have redline 75-140 in my rear. You dont use your front diff as often so you might just want to leave regular gear oil in there. If you drive through water then you should just stay with gearoil front and back. Costs to much money to change out everytime you submerse your axles.
'B'wigstrailrig is offline
post #4 of 138 Old 12-13-2008, 07:06 PM
john NC
john NC's Avatar
1979 CJ5
john NC is offline
post #5 of 138 Old 12-13-2008, 08:01 PM
Sahara01
www.bobistheoilguy.com
sponsored by
, GOODYEAR TIRES,
Sahara01 is offline
post #6 of 138 Old 12-13-2008, 09:16 PM
sportcoupe
Use any 75w-90 gear lube with a GL5 rating, even if you get it from wal-mart. Synthetic is overrated.
sportcoupe is offline
post #7 of 138 Old 12-13-2008, 09:49 PM
roadkill
the book calls for synthetic in the Rubi axles, anyone know why? am I wrong to assume it may have something to do with the axle locking mechanisms, perhaps it helps them lock/unlock quicker. anyone run reg gear lube in them, if so how did they (lockers)do?
roadkill is offline
post #8 of 138 Old 12-13-2008, 10:38 PM
odwaud
amsoil fo sho!
4.0L 5 Speed 2000 TJ.
4.5 in lift composed of RE, JKS, and Skyjacker suspension parts. Currie HD steering
Smittybuilt SRC bumper. AtoZ Rockers. 33" MT Baja Claws
odwaud is offline
post #9 of 138 Old 12-14-2008, 08:02 AM
sportcoupe
I was told by a very reliable source that Currie will void all warranty if they find synthetic gear oil was used in their axle assemblies.
www.bobistheoilguy.com/gearoiltest.htm link above confirms that convertional gear lube performes better then synthetic gear lube.
post #10 of 138 Old 12-14-2008, 08:26 AM
Davetha
Davetha's Avatar
Amsoil seems to work just fine. But since I go through water crossings, I usually just stick with the regular stuff since I change the gear oil often.
Davetha is offline
post #11 of 138 Old 12-14-2008, 09:38 AM
Rubicon05TJ
The Rubicon calls for synthetic because the rear locker is also a limited slip diff. It needs the friction
Rubicon05TJ is offline
post #12 of 138 Old 12-14-2008, 09:47 AM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Valvoline synthetic has the fricion additive ingredient.
http://www.valvoline.com/pages/produ...asp?product=58
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline
post #13 of 138 Old 12-14-2008, 09:53 AM
roadkill
rubi lockers are gear driven and do not need any modifiers, its only the clutch pack style ls that needs the friction modifier.
roadkill is offline
post #14 of 138 Old 12-14-2008, 10:00 AM
BYuen
BYuen's Avatar
X2. The lsd in the rear TJ Rubicon is a helical gear type. No clutch packs so no friction modifier is required
BYuen is offline
post #15 of 138 Old 12-14-2008, 10:05 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Go with what is in your manual so the dealer can't claim you put the wrong stuff in and void your warranty. Just my .02.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
Advice Needed: Red Grease, Marine Grease, Synthetic Grease, Marine Synthetic mixes CB3 TJ Wrangler Technical Forum 5 11-25-2009 01:21 AM
Synthetic oil AFT-4 for front & rear differential? easytim TJ Wrangler Technical Forum 10 03-15-2009 02:05 PM
Differential Fluid - Synthetic? BRAY6 TJ Wrangler Technical Forum 8 04-30-2008 09:32 PM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 01:38 PM
Synthetic, or not synthetic ?? (150K miles) BNovak TJ Wrangler Technical Forum 5 06-09-2004 10:23 PM
