Best solution for a easy Transfer case swap? - JeepForum.com
post #1 of 11 Old 06-24-2010, 09:06 PM Thread Starter
Rayne
I am starting to look into doin a T-case swap in the future and wanted to find a swap that would be a good strong upgrade but that would be fairley easy and wouldn't require to many modifications. Is there anyone who can give me some advice to guide me in the right direction?
^^^^Wind River^^^^
Rayne is offline
post #2 of 11 Old 06-24-2010, 09:08 PM
LuckRider
LuckRider's Avatar
Rubicon 241. 4:1 Low Range, has a fixed yoke output, and can even be made to get the 4wd light to come on. It is also stronger than the factory 231.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #3 of 11 Old 06-24-2010, 09:09 PM
lumpster
lumpster's Avatar
what are you wanting out of a transfercase swap? 231's are good cases, you can get 4 to 1 gears, super short SYE's, 2 low, cable shifter, etc..
lumpster is offline
post #4 of 11 Old 06-24-2010, 09:10 PM
lumpster
lumpster's Avatar
you see alot of broken 231's? that arent taken out by a worn out front driveshaft/
lumpster is offline
post #5 of 11 Old 06-24-2010, 09:13 PM
LuckRider
LuckRider's Avatar
I never said it was a lot stronger, or there was any particular issues with the 231. I agree with you, it is a good case. I think if you are going to be dropping money on an SYE and 4:1, you might as well get a case that is setup like that. I am assuming the OP is looking for a new solution because something happened to his current one.
Support Our Troops!
JFI Member #7:
post #6 of 11 Old 06-24-2010, 09:18 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
run a flipped dana 300.
Mail crawling.
MisfitSeven is offline
post #7 of 11 Old 06-24-2010, 09:40 PM
elkfan2
elkfan2's Avatar
Atlas
elkfan2 is offline
post #8 of 11 Old 06-24-2010, 09:44 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
why do you want to swap the t-case?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 11 Old 06-24-2010, 11:24 PM
JeepnBlake
I wanted to start a Rubi case vs 231 with SYE and 4 to 1 gear set, but that seems like it borderlines hijack.
So I will say my 241 must've had a bad casting cause it had multiple cracks in it.
I think it's very close between the 231 with 4 to 1 and sye and the Rubi case. You could always do the 6 planetary and the hd chain swap, i think you'd be better off doing those mods on the 231.
But like everyone else is saying why do you want to swap your tcase?
I'd say stak or atlas, but its going to take some mods to fit and get them to work.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #10 of 11 Old 06-25-2010, 12:45 AM
RogueSpear2023
I don't really see the point of upgrading to a Rubi 241 it's a fair amount of work especially for the older jeeps that were not made for it. I think upgrading the 231 or going to a Dana 300 with a flip kit are your best cheap options. You can upgrade the 231 with a 4:1 gears, SYE, and it will be plenty strong. Is the 241 stronger yes, but is it really needed not really IMO.
If the sky is the limit I think the only place to look as at an Atlas.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #11 of 11 Old 06-25-2010, 05:27 AM
JeepnBlake
Didn't mention it before, but if you got crazy you could do the 231/300 doubler, there are 2 manufacturers over on pirate that sell kits to do it.
-Blake-
Build Thread:
Dad's Build Thread:
transfer case , swap
Transfer case swap dadstjaz TJ Wrangler Technical Forum 8 11-19-2014 08:07 AM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
QUICK easy transfer case question HELP please JfirEfightErP TJ Wrangler Technical Forum 4 07-23-2009 01:11 PM
easy mirror solution mojo747 YJ Wrangler Technical Forum 8 04-27-2008 10:09 PM
Any easy fix for a leaking transfer case? howellru YJ Wrangler Technical Forum 2 03-23-2007 03:43 PM
