Best selectable locker for D30? - JeepForum.com
post #1 of 6 Old 08-29-2009, 04:12 PM Thread Starter
IH8ROADZ
Okay so here's the final plan Im gonna keep both the D35 and D30. In the rear Im going to be running a detroit locker with the Super 35 Kit (w/ c-clip eliminator). I will also be using a TNT Customs Truss. I figure if people like Silvergoat get keep them going on their TJ why not me. Considering I do Jersey and PA wheeling mostly mud, water, and a few rocks here and there is nothing like you guys have out west. In the front I'll be running a selectable locker haven't decided which one (but DO NOT want to run an ARB). Just have heard too many stories about having to rebuild the seals and what not and I don't want to have to run an air supply. So instead I'll go with an electronic or magnetic actuating locker. Ill also be running the Super 30 Kit also with the TNT Customs Truss. Both will have Riddler diff covers. Please let me know your opinions on a good front locker tho and anything else I should ***. Also the gearing will be 4.88. Thanks!
IH8ROADZ is offline
post #2 of 6 Old 08-29-2009, 04:18 PM
otisdog
2008 WK
There's not a lot of choices left especially if you do the Super 30
The Auburn Ected is actually a dual stage limited slip
Eaton Elocker - I think they make them for the D30 now
Ox locker - has it's own cover and is cable actuated.
Why not just stick to 27 spline alloys - much easier to find if you do break one. Keep the stock axles as spares
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 6 Old 08-29-2009, 05:34 PM
emev0l
ARB or OX
The ARB is air actuated
The OX is cable actuated
There both great lockers, just decide if you want to press a button or pull a lever.
Since your not a fan of ARB I would go with OX
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #4 of 6 Old 08-29-2009, 05:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Personally the rumors of ARB issues are nothing more than internet my brother's buddy's friend's cousin had problems with his or similar BS.
But if you truly are dead-set against the well proven nearly bulletproof ARB air locker (and I run a Detroit Locker so I have no dog in this fight), I'd definitely go for the Eaton E-Locker over the far more difficult to install Ox Locker. Ask Wheelin98TJ about his, he's very happy with it.
Jerry Bransford is online now
post #5 of 6 Old 08-29-2009, 06:51 PM
johnjk
ARB
johnjk is offline
post #6 of 6 Old 08-29-2009, 06:56 PM
05RedRME
Eaton E-Locker
05RedRME is offline
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Selectable locker for D30 besides ARB or OX? 04Willys TJ Wrangler Technical Forum 67 03-29-2007 03:16 PM
Selectable locker options? Z0RR0 TJ Wrangler Technical Forum 7 03-26-2007 10:10 AM
Best selectable locker? Flyingbrass TJ Wrangler Technical Forum 2 11-01-2005 08:53 PM
Selectable Locker for D35??? RabiDaWise YJ Wrangler Technical Forum 6 02-12-2004 09:41 AM
