best mods? - JeepForum.com
post #1 of 70 Old 06-13-2013, 07:46 PM Thread Starter
DaveS01
So. After religiously building Cherokees I've somehow ended up with a 97 TJ after a sporadic trade.
It has a dumb *** 2.5 inch spacer lift, brand new 33" Baja claws, some sort of stinger, some pretty decent high clearance fenders, rear quarter guards, cold air intake..some other random things..
What do you guys think is the best place to start other than general maintenance?
DaveS01 is offline
post #2 of 70 Old 06-13-2013, 07:49 PM
blubaru2002
Post some pics!
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #3 of 70 Old 06-13-2013, 07:52 PM Thread Starter
DaveS01
I will in the morning.
dumb app doesn't like my pics.
I took some night shots with my DSLR setup..I'll post in the a.m.
DaveS01 is offline
post #4 of 70 Old 06-13-2013, 07:57 PM
Gary2
good control arms or at least lower fronts . It will improve on road driving , less steering correction needed.
Gary2 is offline
post #5 of 70 Old 06-13-2013, 07:59 PM
tyvanwie
Well you don't seem satisfied with the spacers, so I would read up on some coils.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #6 of 70 Old 06-13-2013, 08:56 PM Thread Starter
DaveS01
Im thinking someting along the lines of the rock krawler front and rear triangulated long arm setup.
DaveS01 is offline
post #7 of 70 Old 06-13-2013, 08:56 PM
tyvanwie
Why?
tyvanwie is offline
post #8 of 70 Old 06-13-2013, 08:58 PM Thread Starter
DaveS01
Eh:
DaveS01 is offline
post #9 of 70 Old 06-13-2013, 08:58 PM
99_TJ_Wyoming
It depends on what you want from your Jeep. Basically your going to do the same thing you did to the XJs except you'll eventually need a SYE on the TJ, and of course the rear suspension is more like the front than on the XJ, so if your going to build a beach runner, DD, or trail rig start at springs and shocks, if your building a crawler, start with a mental concept of where you want it to be and then prioritize.
Edit: Start with getting rid of the bent tie-rod. Do the ZJ upgrade until you get further in to your build, it's cheap, it's strong and it's very easy to bolt in.
99_TJ_Wyoming is offline
post #10 of 70 Old 06-13-2013, 09:05 PM Thread Starter
DaveS01
Its going to be a crawler.
Do they come stock with a belly skid? This one has a belly skid, and a gas tank skid.
Its funny seeing how short the rear d shaft is on the TJ compared to the XJ I had.
I may just buy some longer shocks, bumpstop it, wheel it a bit, and buy little things here and there until the winter after I get married and have funds available.
Im pumped regardless.
DaveS01 is offline
post #11 of 70 Old 06-13-2013, 09:10 PM
Kodiak17
New front trackbar? That passenger side spring looks a little wack.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #12 of 70 Old 06-13-2013, 09:12 PM
tyvanwie
Yes they come stock with a skid
tyvanwie is offline
post #13 of 70 Old 06-13-2013, 09:12 PM Thread Starter
DaveS01
It sure does..
I think it may just be deceiving from the picture.
DaveS01 is offline
post #14 of 70 Old 06-13-2013, 09:14 PM
tyvanwie
D35 rear? Or has it been changed?
tyvanwie is offline
post #15 of 70 Old 06-13-2013, 09:15 PM Thread Starter
DaveS01
Originally Posted by tyvanwie View Post
Why?
Why not?
Id like to build it right, and not with the typical RC garbage.
May not just go buy that RK setup, but may build something very similar.
I only had about 400 bucks in my xj 3 link setup, and it worked like magic.
DaveS01 is offline
