Best LA Lift WITHOUT Skid Plate? - Page 2 - JeepForum.com
post #16 of 26 Old 08-07-2009, 08:09 AM
snellav
snellav's Avatar
x2
________
98 2 Door Cherokee SE 4x4 - Stock
00 TJ w/ D60s and lotsa other stuff - Gone but not forgotten
snellav is offline
post #17 of 26 Old 08-07-2009, 05:11 PM Thread Starter
rastaangel
well.... whats the LA lift with the highest clearence skid plate?
rastaangel is offline
post #18 of 26 Old 08-07-2009, 06:32 PM
elkfan2
elkfan2's Avatar
You already said you don't want to replace your skid plate so why not take everyone's advice and not go with clayton?
elkfan2 is offline
post #19 of 26 Old 08-07-2009, 06:33 PM
elkfan2
elkfan2's Avatar
its up to you. ask yourself why you want 4-6" of lift. 4-6" of lift is definitely long arm territory.
what tires do you want to run? what terrain do you want to run? where are you getting stuck now that 4-6" of lift is REQUIRED? Do you understand everything that goes along with long arms & big tires? SYE, alloy shafts, brake upgrades, steering upgrades, lockers, etc.
Didn't know you needed lockers to run 4-6" of lift.
elkfan2 is offline
post #20 of 26 Old 08-07-2009, 07:10 PM
#686 Sahara
#686 Sahara's Avatar
x3 on Poly Performance, just had mine installed last week, great ride and very solid feel. Had Full Traction removed due to having the bushings replaced every 12 months. Haven't wheeled it yet, still putting all the little odds ends together.
#686 Sahara is offline
post #21 of 26 Old 08-07-2009, 07:55 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
apparently you did
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #22 of 26 Old 08-08-2009, 10:43 AM
atxzj
I am on the highway alot and my TJ is a DD.
Yes I realize what I am gettign into going into the tires I plan on running, which are 36" irocs
Why are you even considering any swamper product for a DD? The irok is pretty much the thornbirds handicapped cousin. They don't do anything well.
On the plus side, you can keep your D30/44 as they'll never get enough traction to break anything
Old stretch thread:
New stretch thread: http://www.rockymountainextreme.com/showthread.php?t=48591
atxzj is offline
post #23 of 26 Old 08-08-2009, 09:56 PM
Saltine
Saltine's Avatar
I think I just found my new sig. This is by far one of the most "out-there" statements I have ever read.
Rocky Mountain Edition Club, Member #6
Saltine is offline
post #24 of 26 Old 08-08-2009, 10:11 PM
atxzj
least I can do......
Old stretch thread:
atxzj is offline
post #25 of 26 Old 08-08-2009, 10:40 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Originally Posted by SnatchBlock View Post
BDS has a 4.5" and 6.5" longarm bolt on lift that does not require a special skid. Although you may need a super short SYE for the 6.5", since you want to keep your flat belly skid.
http://www.bds-suspension.com/kits/467H
http://www.bds-suspension.com/kits/477H
I've heard nothing but praise concerning BDS shortarm. Haven't seen too many running the longarm though. Good, bad, ugly..?
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #26 of 26 Old 08-09-2009, 09:52 AM
SnatchBlock
I have the 6.5" longarm and have no complaints. It is my DD. Rides better than stock on the road and does a good job of keeping all the tires on the ground off the road.
SnatchBlock is offline
belly up skid plate and sye w/ revolver shackles and lift clayballs YJ Wrangler Technical Forum 3 06-16-2009 01:16 AM
after 4" lift (skid plate qeustion) GhostTJ TJ Wrangler Technical Forum 9 07-29-2008 08:29 AM
Can you run a skid plate without the lowering kit if you have a lift? crossriver125 TJ Wrangler Technical Forum 2 11-09-2007 04:54 PM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
What should I get next? Skid plate? or Hi-lift jack? franco802 TJ Wrangler Technical Forum 16 11-30-2003 04:29 PM
