Best headlight upgrade for a TJ that does not require new wire upgrade?
#1 | |
I have read all of the recent posts about how awsome the IPF lights and fatboy bulbs are but then on top of that 150 you have to upgrade the wires foranother 100 so what is the best upgrade for headlights that does not require a wireing upgrade as well.
Thanks
#2 |
Hella Vision Plus conversion headlamps. I should be receiving mine in a couple days.
Here's JP Magazine's review on aftermarket TJ headlights. http://www.jpmagazine.com/techarticles/electrical/154_0710_jeep_headlight_shootout/index.html |
#3 |
Feeding the money pit
Hella H-4s and a good quality H-4 bulb. ~$75 including shipping from fleabay and they drop right in.
Use a stock wattage bulb and the light increase is significant with no additional wattage draw. The increase is due to better beam pattern and focus not just throwing more light down the road.
Dave Shannon Durango, CO '01 TJ Sahara '98 XJ Sport '00 XJ Wife's ride Gone but not forgotten '56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr |
#4 |
Anyone have a link to purchase these
#5 |
i have the deltas and love them!
4.0L, 5 speed manual, D35 w/ 3.73's, 4" ruff county sus. lift, 33X12.5 Cooper Discoverer's, rubicon style rocker panels, kc front bumper loop with 130w 6" slimlites, Delta 7" Xenon Headlamps, |
#6 |
While the wiring upgrade is a nice touch, its by no means required for the IPF conversion. I've been running them for well over a year with no issues. Looks, however, like the price went up as I believe I bought them for $130 shipped from Northridge back when I upgraded.
Trombino -- '04 TJ -- Rubicon Express 4.5" Superflex + 3/4" Front Spacers, OME Shocks, Currie Rear Shock Relocators, JKS 1.25" BL, JKS BMML, JKS Quicker Discos, 15x8 Cragar Soft 8's, 35x12.50 BFG KM's, LoD Heavy Duty Rear Tire Carrier, Chopped Front Bumper, Uniden 520XL w/ 3' Firestik II, Skyjacker Steering Box Skid, Rusty's Engine Skid, IPF H4 Conversion w/ Fatboys, Hella 500 Windshield Driving Lights, Tomken Gas Tank Skid, ARB Rock Sliders, PSC Rock Ring (D30), Riddler (D44), MV50 OBA, Rusty's Air Tube, TBS, Flowmaster 40, Dana 44 with Trac-Loc, Warn XD9000i w/ Grill Guard The Wife -- '02 KJ Limited -- Pre-Lowered, Full Mopar Skids, 245/70-16 General Grabber AT2's, Trac-Loc Rear, Flowmaster 50 SUV |
#7 |
#8 |
Trust me....
Yet another plug for Roundeyes!
Roundeyes™ introduces a night vision upgrade for the Jeep® owner. Conversion headlamps are designed to replace your OEM issued sealed beam headlights providing you with a much safer night time driving experience. If you have a hard time seeing clearly at night with your stock dim yellow headlights, this upgrade is what you need. Roundeyes™ conversion headlamps will provide you with a whiter and brighter light output allowing you better vision in the fog, rain, snow, and night time driving conditions. - 60% brighter than conventional sealed beam headlamps - H4 60/55 watt bulbs are replaceable - Die-cast aluminum housing with a complex multi surface reflector that produces a wider beam pattern - Unbreakable clear polycarbonate lens - Gortex® breather allows heat to escape while keeping moisture out of the lamp assembly - Lamp assembly can handle off-road bulbs up to 130 watts - Easy drop fit installation with no additional wiring needed Simply unscrew the headlamp bezel, remove and unplug your old sealed beam headlamp and replace them with these. It's that easy! This street legal DOT approved/SAE certified set includes two complete headlamp assemblies with bulbs already installed, ready to plug into your vehicle. The best safety upgrade for you and your family! We can not remove or exchange the DOT approved bulbs for this kit. Higher wattage bulbs are sold separately and are for off-road use only. To be installed by the customer. See "Auxiliary Bulbs" in the main menu. Does not fit Jeep Liberty. FREE SHIPPING - LIMITED TIME OFFER! Price:$ 109.00 / pair
Patriot Blue 2001 TJ Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires. My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/ |
#9 |
X2 on trombino's experience. I run the IPF/Fatboy combo with stock 99 TJ wiring and they work GREAT.
#10 |
ROCK WHEELER
I don't know what the big deal is with IPF's and fatboys, I installed Delta's with Silverstars and am quite happy with them (at a lower cost might I add).
http://www.quadratec.com/products/97009_111.htm with Silverstars from my local auto parts store is good, I have had many compliments on the set-up in the California Deserts.
___________________________________________ In or Near San Diego, CA? Click Here Black Jeep Club Member #1016 Senior Member: Jeep Repair Club, San Diego Chapter
#11 |
#12 |
x3 Big difference over stock w/IPF/Fatboys
2006 TJ Sport Red 6-speed; D30/D44 w/3.73; 33"x12.5 MTRs; Skid Row Engine/Steering Skids; AtoZ Rockers and Rear Bumper/Tire Carrier; Rockcrusher and T&J Diff Covers; 4WheelCustoms 2.25" BB; M.O.R.E 1" MML; PA 1" BL; Mike Green LCA Skids; Uniden Pro510XL w/2' Firestik; Husky Floor Liners Lone Star Jeep Club |
#13 |
99 TJ Low Output Model |
#14 | |
Silverstars are a VAST improvment over stock. They really are extremely bright. Looks more like aircraft lighting (which I have experiance with) than automobile lighting.
#15 |
Just violated my Parole
you dont have to upgrading the wirings for the IPF kit, i didnt, and i get flashed very now and then even with them aimed properly
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
