Best engine oil to use in a 4.0? - JeepForum.com
post #1 of 24 Old 11-02-2010, 09:47 AM Thread Starter
JimE2
2014 JK Wrangler
Getting ready to change my oil, and heard these straight 6's don't like synthetic oil, causes them to leak. Don't want to mess anything up, so I thought I would ask, for a Texas Jeep, what is a good oil to put into a TJ with 112K on it?
JimE2 is offline
post #2 of 24 Old 11-02-2010, 09:49 AM
Caribic-TJ
yes, no need to buy expensive synthetic oil.
Caribic-TJ is offline
post #3 of 24 Old 11-02-2010, 09:51 AM
JBTJ
That is like asking what is the best kind of air to breath. Any oil is good. That being said, I have three JEEPS with the straight six and use nothing but synthetic for the past 30 years. No leaks no problems. This is a can of worms where everyone will say something different.
JBTJ is offline
post #4 of 24 Old 11-02-2010, 09:53 AM
Night Wolf
My oil of choice is Shell Rotella T/Chevron Delo/Mobil Delvac 15w-40.
Night Wolf is offline
post #5 of 24 Old 11-02-2010, 10:24 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Synthetic oil doesn't cause anything to leak.It finds spaces that regular oil can't get out of and does. Valvoline and Castrol GTX are good.
TheBoogieman is offline
post #6 of 24 Old 11-02-2010, 10:55 AM
Speed94
what weight are you guys using?
97 TJ PD club member #007
Speed94 is offline
post #7 of 24 Old 11-02-2010, 10:57 AM
g4x4xgeoff
I run 10w-30 castrol conventional in mine.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #8 of 24 Old 11-02-2010, 11:09 AM
YellowX
YellowX's Avatar
10w30 Quaker State High Mileage here. I know guys that have had this motor for years, and only bought what was on sale, never had a problem. Know guys that use Mobil 1 and have all kids of problems. Then again, I also know the complete opposite of what I just posted. So, to each their own. Each Jeep is completely different.
Fred
JAFGJ
YellowX is offline
post #9 of 24 Old 11-02-2010, 11:30 AM
wpparker
10w-30 GTX works good
wpparker is offline
post #10 of 24 Old 11-02-2010, 11:32 AM
33shooter
I have used Mobil 1 in every vehicle I've ever owned with great results. I would also suggest amsoil and royal purple as well, but those are expensive and not really worth it for engine oil IMO. I change my oil every 5-6k miles
33shooter is offline
post #11 of 24 Old 11-02-2010, 12:03 PM
bairy
The best oil to use is..... NEW OIL.
Just keep changing it.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #12 of 24 Old 11-02-2010, 12:13 PM
Jetscuh
O rly?
2015
Yep.
If you drive a lot and put many miles on your TJ in a short amount of time then you could switch to synthetic just to gain some time between oil changes.
Jetscuh is offline
post #13 of 24 Old 11-02-2010, 12:30 PM Thread Starter
JimE2
2014 JK Wrangler
Good point. Did not think of it that way. Makes sense to me!
JimE2 is offline
post #14 of 24 Old 11-02-2010, 12:30 PM
Woodenya
Valvoline 10w30 is what I look for...
'06 TJ Rubi (Light Metalic Khaki) 6sp, Bought 3-10 w/6500 miles. 31 MTR's, UCF alum UHC T-case & engine skid w/ LoPro, Rokmen gas tank & steer gear skid, Ridler dif covers F/R, Warn 8274-50, Optima Yellow top, Pro Comp front 3/4" spacers, Currie 1" BL, Bomb Proof MML, Novak cable shifter, AGR Super Box 2, Warn rear bumper/tire carrier, Rubi locker mod/pumps moved to engine bay, OBA. Build to come...
Woodenya is offline
post #15 of 24 Old 11-02-2010, 12:32 PM Thread Starter
JimE2
2014 JK Wrangler
Does it do any harm switching back to regular [new] oil, from, say unknown or possibly synthetic oil? I really have no idea what is in it right now, and want to switch to a known good oil of proper weight for Texas.
JimE2 is offline
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 11:23 AM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 07:00 PM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 02:08 PM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 08:57 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
