Best engine coolant? - JeepForum.com
post #1 of 33 Old 07-20-2010, 10:39 AM Thread Starter
BChamberlin
BChamberlin's Avatar
Stick with Prestone or should I try the Royal Purple stuff? Don't mean to be a nerd but I'm putting a new radiator in my Jeep tonight and I'd like to start off right.
Thanks,
Is there a better brand of coolant? Orange, green? I've always just used what was available. I'd like to change my lazy ways. And yes I searched the forums... like a needle in a hay stack.
2008 Wrangler X
BChamberlin is offline
post #2 of 33 Old 07-20-2010, 10:45 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
HOAT is the good stuff but your TJ's cooling system really needs to be flushed thoroughly before changing to HOAT which will outlast any other type of coolant. I would stick with Prestone who has been making coolant a lot longer than Royal Purple who likely just buys it from someone else anyway.
Whatever coolant you decide on, be sure to ONLY mix it with distilled water like is sold by the gallon in your local grocery store, don't use tap water. That is if the coolant you buy is concentrated and requires water be mixed in with it which is the more economical way to buy it. Pre-mixed coolants are a lot more expensive for what you get.
Getting
Jerry Bransford is online now
post #3 of 33 Old 07-20-2010, 11:00 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Zerex GO5 + distilled water. flush well with a Prestone flush kit + garden hose. color means nothing...stop thinking in terms of color...thats just dye. do NOT use Dex-Cool.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 33 Old 07-20-2010, 11:02 AM Thread Starter
BChamberlin
I'm replacing the radiator so I really only need to fliush the block.
2008 Wrangler X
post #5 of 33 Old 07-20-2010, 11:03 AM
Unlimited04
and the heater core and all hoses....
Useful Write-Ups:
Funny:
post #6 of 33 Old 07-20-2010, 11:13 AM Thread Starter
BChamberlin
Looked on the prestone site and didn't see anything like hoat...
2008 Wrangler X
post #7 of 33 Old 07-20-2010, 11:18 AM
Jerry Bransford
Administrator
Prestone's extended life antifreeze/coolant is HOAT based.
Getting
post #8 of 33 Old 07-20-2010, 11:21 AM
Sundowner
I have trouble finding the HOAT stuff around here as well. Everything is purely glycol-based... (Edit: Meaning, I can't find anything with a HOAT additive.)
Sundowner is offline
post #9 of 33 Old 07-20-2010, 11:24 AM
MountainMan864
People have been using the cheap stuff for years. People say you need this and you need that. Screw that just put the good ol stuff back in. Youll be fine. Like everyone says you need currie ca's rockjocks etc. blah blah blah
MountainMan864 is offline
post #10 of 33 Old 07-20-2010, 11:39 AM
Sundowner
People also rode horses for years...until the automobile made that form of transportation mostly obsolete. Just because something was used "for years" doesn't make it superior; conversely, the relative newness of any given product doesn't make it superior, either. In this case, everything I've heard about HOAT allows me to easily pick products with it over the plain glycol alternatives, and to pay a bit more for them as well.
post #11 of 33 Old 07-20-2010, 12:15 PM
freeskier93
Color is actually very significant. Green is the original non organic, some would say "universal" coolant. Orange, pink, dark green, and some other colors are OAT the organic coolants that you don't want to mix with green because you lose ALL benefits of OAT. You also do not want to put OAT coolants in older cars that have brass/copper radiators and heater cores because it will reduce their life.
Personally, the original Prestone Green is the best. Only advantage to the organic coolants is they last longer. Green is cheaper, can be found at any gas station and auto parts store, and as long as you change it regularly you will have no problems.
freeskier93 is offline
post #12 of 33 Old 07-20-2010, 12:44 PM
tjkj2002
2002 KJ Liberty
Color means nothing anymore in coolants.
The OEM HOAT Chrysler is orange,Zerex GO5(HOAT) is yellow,same stuff different dyes.OAT coolants(Dexacool and it's clones) come in green,blue,yellow,red,orange,and pink.
Just because it's green does not make it the "old school" IAT Ethylene Glycol.
FYI..............
Prestone only makes OAT coolants(Dexacool clones),they do not offer any HOAT coolants.
All Makes/All Models Claims
Honeywell's advertisements and product labeling claim that Prestone extended life antifreeze/coolant can be used in vehicles of "all makes, all models."
The panel determined that one reasonable consumer takeaway from the "all makes, all models" claim is that Prestone meets any required specifications established by vehicle manufacturers.
Prestone utilizes Organic Acid Technology (OAT). Ford and DaimlerChrysler vehicles of recent vintage have antifreeze/coolant that utilizes Hybrid Organic Acid Technology (HOAT), and Ford and DaimlerChrysler specifications call for HOAT antifreeze/coolants in their vehicles. Ford and DaimlerChrysler account for a significant number of vehicle sales in the United States, and their specifications requiring HOAT antifreeze/coolants, as well as their warnings to consumers about possible damage if OAT antifreeze/coolants are used, are enough to establish that the "meets manufacturer specifications" message has not been substantiated.
tjkj2002 is offline
post #13 of 33 Old 07-20-2010, 01:01 PM
Jerry Bransford
Administrator
If that is true, I withdraw my above recommendation for Prestone's Extended Life coolant. I would not install any OAT type coolant into a Jeep. I had read in several locations, not Prestone's website however that did not say, that their 5 year coolant was HOAT, so I'm not sure now if it is or not. I'm going to try to find out for sure.
Getting
post #14 of 33 Old 07-20-2010, 01:16 PM
Unlimited04
Last time I looked on their website, nothing Prestone made was "approved" Chrysler MS-9769 (HOAT spec). Zerex GO5 is MS-9769 spec'ed, and is authorized for use in Ford, Chrysler and Mercedes vehicles requiring HOAT.
Useful Write-Ups:
Funny:
post #15 of 33 Old 07-20-2010, 01:28 PM
Jerry Bransford
Administrator
From Prestone's website page at Prestone :: Car Care : FAQ
When tested in ASTM D 1384, D 4340, D 2570, and D 2809, Prestone® Extended Life 5/150 Antifreeze/Coolant will meet the chemical, physical property characteristics and performance requirements of the following standards and specifications:
GM 1825M
GM 1899
Ford WSE-M97B44-A
Ford ESE-M97B44-B
DaimlerChrysler MS 7170 and MS 9769
General Services Administration A-A-52624
ASTM D 3306
SAE J 1034
ASTM D 4985
So if the MS 9769 is indeed a HOAT spec as you say it is, that Prestone's Extended Life coolant does indeed meet the HOAT spec.
Getting
coolant , best , advice , help , radiator , TJ
Should I have engine coolant in here? skream YJ Wrangler Technical Forum 39 02-07-2009 11:41 AM
4.0L Engine Coolant valacech TJ Wrangler Technical Forum 9 02-12-2008 03:51 AM
Engine Coolant WittSmall TJ Wrangler Technical Forum 3 01-04-2008 09:26 AM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 09:57 PM
Engine Coolant glumun TJ Wrangler Technical Forum 3 04-17-2003 11:55 PM
