Best/Cheapest lift - Page 2 - JeepForum.com
post #16 of 58 Old 02-10-2014, 08:58 AM
Ross
Originally Posted by Eckoh View Post
a good winch can cost you more then a complete lift kit.
I do agree that research is key. However with all things jeep staying in a budget and doing it right is not as easily done as it is said. You never know what issue you might run into and need to fix along the way. Its better to take it slow and do LOTS AND LOTS of research. Its better to spend more and cry once then it is to go cheap and cry twice having to fix it later.
What is wrong with a 2" susp lift and a body lift. I know many who have run that with 33s and never seen one of them in tears .
If budget is the issue I would rather go with a 2" spring or spacer and keep the stock control arms and not have to deal with drive line vibes. That is a good way to keep within a low budget. Even if budget isn't an issue I would prefer the lower center of gravity type build. Once you lift much further than 2" you may run into driveline issues. At that point you have extra things to deal with. The money saved on new control arms, MML, SYE or whatever maybe needed to run a higher suspension lift can be used for a winch, if the budget allows.
There are many running lower suspension and still clearing larger tires. I would rather keep my lift minimal and consternate on a belly-up, fenders that allow for larger tires (once the rear axle is up to task), and have a winch as opposed to laying out a $1000 for control arms, $500 plus for a new rear drive shaft and SYE kit Just so I can properly run a higher suspension lift.
A big susp lift just isn't neccessary anymore to make a good jeep that perfoms very well on both the street and the trail.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is online now
post #17 of 58 Old 02-10-2014, 09:54 AM
thedaringmove
I agree with Ross above.
The smart thing for you to do would be buy a 1" body lift and 2" coil spacers. You will spend less than 500. Then in the future you can swap springs(if you ever feel the need)
Here's a complete list of things you should get
-2" spacers
-shocks
-rear Trackbar relocation bracket
-1" body lift
-1" motor mount lift
-tires
-wheels with the right amount of backspace or spacers
This is my personal setup except I'm on 35s and also have tube fenders.
Good luck! I hope you choose this route
thedaringmove is offline
post #18 of 58 Old 02-10-2014, 10:22 AM
SouthFLJeeper
SouthFLJeeper's Avatar
I've thought about going the route you have with yours. Do you have any pics of your setup?
-2" spacers
-shocks
-1" body lift
-tires
'00 TJ Sahara - 1" Body Lift, awaiting many upgades
'00 TJ Sahara (R.I.P.) - 2.5" Rancho Lift, 2" BB, 1" Body Lift, 35" XTerrain's, Warn 9000lb Winch, Warn Bumpers & Sliders
'05 Excursion 6.0 Diesel
SouthFLJeeper is offline
post #19 of 58 Old 02-10-2014, 10:55 AM
pierps
BDS 2" suspension lift, 1.25" body lift, and a 1" motor mount lift.
If you get driveline vibrations, add a LoPro transmission mount.
This setup will cost probably $600 or so all in.
Go much higher with the suspension lift and you quickly get into the thousands to do it right (sye, dc driveshaft, adjustable control arms).
Also, if you're on a budget, don't forget that larger tires may require to to regear your axles. I have 3.73's on 33" tires and it is tolerable, but most rigs come with 3.07's.
pierps is offline
post #20 of 58 Old 02-10-2014, 11:09 AM
thedaringmove
Originally Posted by pierps
BDS 2" suspension lift, 1.25" body lift, and a 1" motor mount lift. If you get driveline vibrations, add a LoPro transmission mount. This setup will cost probably $600 or so all in. Go much higher with the suspension lift and you quickly get into the thousands to do it right (sye, dc driveshaft, adjustable control arms). Also, if you're on a budget, don't forget that larger tires may require to to regear your axles. I have 3.73's on 33" tires and it is tolerable, but most rigs come with 3.07's.
Nice job reading the thread...
post #21 of 58 Old 02-10-2014, 11:12 AM
thedaringmove
Sure!
post #22 of 58 Old 02-10-2014, 11:22 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
2.25" BB spacers,shocks and a 1" BL on 33's.NOTHING else was done.BB and BL cost $350.
TheBoogieman is offline
post #23 of 58 Old 02-10-2014, 11:30 AM
Ross
And I bet it goes off road just fine. Add some locker and it will go about anywhere you want it to.
There are people here that think you have to spend thousands and thousands of dollars to get a jeep to be a good off roader, which just isnít the case.
Ross is online now
post #24 of 58 Old 02-10-2014, 11:35 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Originally Posted by AmnSyd View Post
Zone 4.25" combo kit. Cant go wrong for the price. I think its around 600.
I'm a fan of this lift for some one who wants 4" of lift on a budget. The Zone 4.25" Combination Lift Kit is a 3" suspension lift with a 1.25" body lift and a 1" motor mount lift. This combination allows you to clear 35's and takes care of your drive line angles to keep you vibration free.
Let me know what questions you have about the lift and if you'd like a quote!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #25 of 58 Old 02-10-2014, 11:35 AM
TheBoogieman
post #26 of 58 Old 02-10-2014, 11:37 AM
thedaringmove
And I bet it goes off road just fine. Add some locker and it will go about anywhere you want it to. There are people here that think you have to spend thousands and thousands of dollars to get a jeep to be a good off roader, which just isn’t the case.
Ross I think were friends
post #27 of 58 Old 02-10-2014, 11:39 AM
Ross
I didn't think I was allowed to have any friends here unless I purchased certain parts.
Ross is online now
post #28 of 58 Old 02-10-2014, 11:49 AM
thedaringmove
Must be a forum revolution
post #29 of 58 Old 02-10-2014, 11:52 AM
Ross
Not a revolution, just a revelation.
Ross is online now
post #30 of 58 Old 02-10-2014, 12:00 PM
pierps
Relax. I read every word. My opinion aligns with the opinions of others in this thread. Just casting another vote.
pierps is offline
body lift , cheap , lift , lift advice , suspension lift
