Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > TJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 03-27-2009, 08:56 PM   #16
Unlimited04
Unlimited04's Avatar
Originally Posted by Maxxram View Post
I just picked up a slightly used Toys by Troy cage and noticed that it does not reconnect to the upper corners of the windshield. Does this affect the structural integrity of the windshield?
the windshield is held in its upright position by two things - there are two little bolts on the base of the hinge, and the windshield bars. You want to keep the windshield bolted to your new roll bar. While it doesn't provide structural integrity, it will keep it from flapping around in a roll. keeping it attached your new roll bar keeps the spacing necessary for the soft top and hard top intact, and if you do roll, it won't go bouncing between the hood and the roll bar like a 75lb pinball.
As you can see in this pic, the windshield hinge is not a strong point:
Unlimited04 is online now   Reply With Quote
Old 03-27-2009, 09:05 PM   #17
GOLENJEEPTJ
Running Amok!
GOLENJEEPTJ's Avatar
True,I have the ORF cage and it also is supported on both sides, by 2 bolts on the top of the windshield.
GOLENJEEPTJ is online now   Reply With Quote
Old 03-27-2009, 09:14 PM   #18
never monday
not trying to be an *** here. but that pic is deceptive. The pivot bolt is intact. the hinge failed. With a cage in place the windshield couldn't fail in that direction. It would end up against the cage.
never monday is offline   Reply With Quote
Old 03-27-2009, 09:36 PM   #19
Unlimited04
I know you've folded your windshield down and even taken it off. With my windshield, there is enough movement at the top of the windshield to throw off hard top and door surround alignment. The hinge and those two little bolts will fail in a roll, and when they do...why create a flying projectile? The windshield will likely end up against the cage, I agree, but if that bolt does break, or the hinge breaks, its going to be bouncing around. The hinge nor the bolt was designed to support the windshield while going down the highway (force of air over large area), let alone support itself in a roll.
Those bolts are only designed to hold the windshield in place while you remove or reinstall the windshield support bars when lowering/raising the windshield - Jeep even states this on their instructional VHS that comes with the Jeep (at least it did in 2004). I think they even say "Windshield Support Bars", or something along those lines, alluding to the windshield roll bars being the main support for the windshield.
thats why I kept mine:
Old 03-27-2009, 09:49 PM   #20
WillysEdition04
CantonCustomCrawlers
WillysEdition04's Avatar
Can't you use the footman loop and a good strap to keep the windshield in it's upright position? (tie the windshield to the forward spreader bar via the footman loop) It's the same way you keep it on the windshield when folded down
04 TJ Willys Edition 41MB-04TJ #4913
97 TJ Dedicated Trail Rig/Project Vehicle: Armored by Offroad Utopia
The WILLYS Edition Owners Group
TJ Tech BOOT CAMP: A must-read for new TJ owners/forum members
WillysEdition04 is offline   Reply With Quote
Old 03-27-2009, 09:56 PM   #21
never monday
I've had my windshield on unsupported up to about 60mph. There didn't appear to be any movement. I was topless at the time so i can't comment about the fit. the windshields is what 2" wide at the bottom. I think it sits on a nice shelf. The upper tie ins help it stay snug.
Old 03-27-2009, 10:09 PM   #22
LGriffith
I just started to look at some cages, and think am eventually going to go with the OR FAB sport cage. I don't wheel hard too often but that extra cage I think would be a good investment. It doesn't look like it, but OR Fab doesn't do a rear spreader(?) bar. Would that be a good thing to add or is it just not real necessary?
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 03-27-2009, 10:11 PM   #23
Unlimited04
I feel the rear spreader is necessary on an LJ.
Old 03-27-2009, 10:11 PM   #24
never monday
I flopped the TJ with the stock rear bars and bent one over.
Old 03-27-2009, 10:14 PM   #25
Unlimited04
yea, and LJ's are quite long. I was able to flex mine by hand by around 3/16". I stood on the tire and yanked with all my weight while my friend slide the PSC spreader in for welding.
Old 03-27-2009, 10:16 PM   #26
LGriffith
Okay, i see. I guess when it comes time for the cage I can have a rear spreader bent for me.
LGriffith LJ Build
Old 03-27-2009, 10:17 PM   #27
never monday
if you want a bot in rear spreader, by the rockhard.
Old 03-27-2009, 10:24 PM   #28
LGriffith
Would that seem like a decent path for some moderate wheeling? OR Fab sport cage with the Rock Hard rear spreader?
LGriffith LJ Build
Old 03-27-2009, 10:28 PM   #29
wrangler2007
That'd be a great setup, but then again the whole rockhard cage would be great too lol, but for the budget I'd say that setup would be fine
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Truxport
wrangler2007 is offline   Reply With Quote
Old 03-27-2009, 10:33 PM   #30
LGriffith
Sounds like a plan for this summer. . Thanks guys
LGriffith LJ Build
Will a YJ bolt in cage fit a TJ? txfiremn TJ Technical Forum 1 02-05-2009 09:46 PM
M.O.R.E Bolt-In Cage cbr929rr TJ Technical Forum 7 03-31-2007 11:11 AM
how much do you think the PSC bolt in cage will run? kaketj TJ Technical Forum 1 07-03-2006 12:51 PM
More Bolt-In Cage 93YJjeep YJ Technical Forum 16 10-01-2004 11:17 AM
TBT Bolt In Cage kaleid TJ Technical Forum 27 09-09-2004 06:37 AM
The time now is 04:53 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
