Best Battery - JeepForum.com
post #1 of 120 Old 01-23-2011, 01:50 AM Thread Starter
ColoradoCole
Best Battery
What is the best battery to use for my set up? Yellow Top Optima or what?
I run 8 light on top for short periods of time and a CB, dual fans 12 inch and 18 inch all the time while running. And i do have a 200 watt sub but thats hardly ever on. I will be adding a winch in the near future if this helps at all.
Right now my volt meter shows just under 14, which means i have a dying alternator, but I'm not too worried about that, i will get one from a durango soon.
ColoradoCole is offline
post #2 of 120 Old 01-23-2011, 02:18 AM
monkeee2002
Searching the forums will net you a lot of info on batteries.
INCLUDING, many personal experiences with Optima's slipping quality. It seems they don't last long at all anymore.
Diehard P4 from Sears seems popular, but may be discontinued.
The skinny pedal on the right is my friend. the gas gauge is not.
monkeee2002 is offline
post #3 of 120 Old 01-23-2011, 02:20 AM Thread Starter
ColoradoCole
So Optima's arent good anymore amazing glad i didn't spend the money.
post #4 of 120 Old 01-23-2011, 02:33 AM
The_Blacksmith
1993 XJ Cherokee
yeah the company was bought out, and now the quality is slipping.
Tho most places have like 7 -8 year warrentys with a 3 years free replacement so a battery is a battery.
I heard good things about the p4 too.
Thanks Chris!
The_Blacksmith is offline
post #5 of 120 Old 01-23-2011, 02:49 AM Thread Starter
ColoradoCole
what do you mean P4
post #6 of 120 Old 01-23-2011, 03:22 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Originally Posted by ColoradoCole View Post
what do you mean P4
Platinum 4.
http://www.mysears.com/DieHard-Autom...e-review-af970
TheBoogieman is offline
post #7 of 120 Old 01-23-2011, 03:56 AM
jeffjeep1
jeffjeep1's Avatar
I have three Odysseys. A PC1500 in the LJ. Actually had it in a 2002 TJ (since June 2005) before I put it in the LJ. It sees winching twice per month, plus daily driving for two weeks, then sits for a week un-used. It has been drained down (headlights left on twice for 8 hours) and keeps working
Also have an Odyssey PC1700 in the Sequoia. It has been installed since Dec 2004, drained down three times. Still working. Left the Sequoia out in 6Deg F overnight recently, started right up.
Third is a PC2250 in the trailer as a deep cycle unit. Again, boring story, no problems.
All stay very clean, no growth of acid crystals. The Sears Platinum Die-hard is reportedly the same as an Odyssey, but less costly.
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #8 of 120 Old 01-23-2011, 05:53 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2 on the Diehard Platinum P1 or P4.
avoid Optima....the new ones suck and don't last long.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 120 Old 01-23-2011, 06:15 AM
MeatPuppet
MeatPuppet's Avatar
I looked at Sears, looks like the P1 has 135 minutes of reserve and the P5 has 100. The P3 has 90 minutes and is a dual post model.
Can the P1 be purchased with dual posts?
The “meat puppet” is a peculiar inhabitant of the digital world—a fictional character that passes for a real person online.
MeatPuppet is offline
post #10 of 120 Old 01-23-2011, 06:19 AM
Unlimited04
look at the group size. TJ's use 34/78DT's. P1 or P4 are that size. P4 is a P1 with dual posts.
Useful Write-Ups:
Funny:
post #11 of 120 Old 01-23-2011, 06:36 AM
Boundless
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #12 of 120 Old 01-23-2011, 06:45 AM
Jeeper2610
Go with a P4 and stay away from the optima like others have stated. Just a side note the batteries I really liked were Bosch, some of the best batteries I ever had were Bosch, but now I can't seem to find them anywhere.
"Just because you got the monkey off your back doesn't mean the circus has left town."
Jeeper2610 is offline
post #13 of 120 Old 01-23-2011, 07:28 AM
basssolow5
nope, this is normal voltage. mine reads about that. alternators normally put out 13.2-14.6ish.
colorado jeep club member #730
stimulating the economy one part at a time!
basssolow5 is offline
post #14 of 120 Old 01-23-2011, 07:46 AM
kolky
I run a P1 and have never had a problem with it. Great battery and great warranty.
Yellow Jeep Club #1224
kolky is offline
post #15 of 120 Old 01-23-2011, 11:40 AM Thread Starter
ColoradoCole
Thanks for all the imput, i will most likely be getting a P4 this weekend. One other question does anyone know if they make a battery tray specifically for the P4 im doing a search now and will edit this if i answer my own question.
Smittybilt Dual Battery Tray & Battery Temp Sensor. 05jeeper TJ Wrangler Technical Forum 6 07-23-2010 08:32 AM
YJ losing battery juice while running-battery/alternator good Dannyboy6292 YJ Wrangler Technical Forum 20 01-13-2010 11:54 AM
Dual battery placement.. will (blank) hurt a battery? jeepgunner12 TJ Wrangler Technical Forum 5 01-04-2010 02:09 PM
battery dead ....argh... dual battery setup???? asjeep TJ Wrangler Technical Forum 21 07-20-2009 05:46 AM
New battery + working alternator = battery still won't charge pyro9862 YJ Wrangler Technical Forum 7 10-28-2007 08:51 PM
