#1 | |
Best Axle width
I got in a discussion today about the best width for a TJ. I thought it would be good to present the discussion to the masses....
What is everybody running and do you like it the way it is or do you wish you would have went a different way..... Thanks for everybodys opinion....
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories..... [URL=http://www.Offroadoverstock.com ] Visit Offroadoverstock.com [/URL] Biff |
#2 |
throbbing member
I don't have an aftermarket axle assembly YET but I have been looking at axle assemblies and such and have been talking to many axle builders. The general concensus seems to be at ~63-64" WMS to WMS for a tj. One of the reasons is that if you are looking at an axle with a centersection larger than a D44 it makes it much easier to mount all of the brackets for a tj. And most have recommended a wheel with a backspacing around 4" with this width.
running like a raped ape |
#3 |
I'm currently hording up parts to stretch my wheelbase and will be going with 69" axles
#4 |
I think this is one of those auto vs. manual type things. All depends. You can run a wider axle with more backspacing and still look stock... or be a pureist and run a stock width around 60". Wider will of course giver you more lateral stability on off camber stuff and get your tires out of the normal jeep width ruts. Of course, wider will be harder to squeeze between trees and possibly hurt your turning radius some. Then there is the legal problems if you are running it on the street and the tires stick out too far.
Louisiana 4X4 '97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2 GeauxLook@myJeep |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
