Best articulating 5.5" lift? - JeepForum.com
post #1 of 31 Old 12-03-2006, 10:56 AM Thread Starter
m1a convert
What lift articulates the best in the 5.5" range and costing less then $4000?
I have been looking at the Rock Krawler, Fabtech, Rubicon Express and nth degree. Which of these is the best and are there others I should look at?
m1a convert is offline
post #2 of 31 Old 12-03-2006, 11:30 AM
Sahara01
RockKrawler X-Factor Plus 5.5 long arm system....here's a link to some pic's of the build on my jeep with install pic's on that system....system flexs so well it is nessasary to use limiting straps to keep from dropping the springs out or over extending your shocks....about $2399.
http://www.slackeroffroad.com/photo/...s.php?album=76
Shortbus Offroad Team #242
sponsored by
, GOODYEAR TIRES,
, Solid Axle Industries, Genright,
Sahara01 is offline
post #3 of 31 Old 12-03-2006, 11:39 AM
ImSuck
ImSuck's Avatar
1997
that jeeps looks freakin awesome
-Andrew
Low Output 4 Cylinder Jeep Club member #59
Originally Posted by Grewe02
No such thing. Eat **** and die.
lifted with some extra's
......sold
ImSuck is offline
post #4 of 31 Old 12-03-2006, 12:57 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Also look at the Clayton kit and the TNT customs kit. I'm going to build one like the clayton kit to save some $$
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #5 of 31 Old 12-03-2006, 05:24 PM Thread Starter
m1a convert
Is there a link for the Clayton kit? Who is TNT?
post #6 of 31 Old 12-03-2006, 06:50 PM
dirtgrip
dirtgrip's Avatar
http://www.claytonoffroad.com/
http://www.tntcustoms.com/webV4/default.asp You may have to go here for info on their new LA lift:http://www.colorado4x4.org/
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #7 of 31 Old 12-03-2006, 09:30 PM
mckaax
http://rustysoffroad.com/Merchant2/m...ode=sus_tj_kit
Midnight Blue 06 X, 5.5 Rusty's LONG ARM kit, JKS Quickers , AA-SYE/My shafts a Woody, 35" GoodYear Wrangler MT/R, 4.56 Gears, Rustys OTK Steering, Eagle Alloys Fake Bead lock 15x8, Lightbar W/ Lots of Lights, Rock Crawler SRC Rocker Guards, 48 in High-Lift. LOD Rear Bumper/Tire Carrier. BUILT BY ME!
Blue Jeep Club Member #227
mckaax is offline
post #8 of 31 Old 12-04-2006, 02:47 PM
Scorpion
Originally Posted by dirtgrip
Not anymore! The website has been updated and info is now available regarding the kit. http://www.tntcustoms.com/webv5/tjylinksystem.asp
With that said, there are a few more updates that aren't on the website (new info as of today) that you may want to be aware of:
  • The Late Model TJ kit has been completed and is now also available effective 12-11-2006.
  • A last minute design revision added two more benefits: (1) Removeable skid plate without having to touch the suspension to make any necessary maintainence. The previous version had the front control arms integrated into the skid. (2) Less complicated install. The new design makes accessing all of the bolts a snap.
  • We have not yet confirmed that the final version works with the Rubicon model. We will update the site as soon as we can confirm it's good to go.
Scorpion is offline
post #9 of 31 Old 12-04-2006, 07:22 PM Thread Starter
m1a convert
I am sure all the kits are good. Which articulates the best?
Krawlers kit is the first kit I have seen to give a RTI score. They also have a tech section on the site that makes a lot of sense on why theres is the best. I don't mean sale lit. but actual pro/con on 3 link vs 4 link etc.
Most of the other kits seem to say "We have a long arm kit with 3 link in the back" and leave it at that. So, what design elements will give us the best flex.
post #10 of 31 Old 12-07-2006, 08:28 PM
Sahara01
RK uses a 20 degree ramp. Most rti's are done on a 30 degree ramp, so it's a little misleading, but having wheeled with quite a few guy's running the 5.5 X-factor long arm kit, it flex's like nothing else I've seen....once my rigs out on the trail I will have plenty of pic's to post to show the flex....and why I use limiting straps....
sponsored by
, GOODYEAR TIRES,
Sahara01 is offline
post #11 of 31 Old 12-08-2006, 07:21 AM
RockYacht
Matt fohgot one key oint to the new M.A.S.S. (Modular Advanced Suspension System) kits. The transmission has it's own independent crossmember. The belly skid can be removed with common hand tools at any time without supporting the trans/tcase.
Benifts?
1)High clearance front control arms
2) Dual triangulated rear suspension. (Check the suspension induced rear steer in the following pics)
3) Full rear axle truss (weld on, no bolt on bracket assy that is called a truss)
4) Removeable skid, without having to support the tranny/tcase
5) All mounting points are frenched (tucked into the mounting system)
Flex?
Here's a Clayton's stretch kit:
Here's our M.A.S.S. IV Y-Link. BTW it's on a YJ...
TJ went 80" up the ramp, YJ 91" That's a 30* ramp.
TNT Customs, Inc. "Master Your Terrain"
contact:
or 307-775-9565
RockYacht is offline
post #12 of 31 Old 12-08-2006, 12:08 PM
Dozer.
Dozer.'s Avatar
Yeah... if that thing every gets back out on a trail
--Nicholas--
Lock'd, Rock'd, but not ready to roll.
Dozer. is offline
post #13 of 31 Old 12-08-2006, 12:13 PM
Sahara01
^^^^^^^^^^^ Dozer.....
sponsored by
, GOODYEAR TIRES,
Sahara01 is offline
post #14 of 31 Old 12-08-2006, 12:26 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I think pure articulation is overrated. If I had $4k to spend on my suspension, it would be a stretched Clayton setup... there isn't really anything tougher on the market.
I also like the Nth stretch kit... which is a tad higher at $4500, but it does include the tank and such. I've heard no complaints about the strength of the kit (ask Dozer) and the ground clearance is fantastic.
I'll be Savvy someday!
neZZr is offline
post #15 of 31 Old 12-09-2006, 09:03 PM Thread Starter
m1a convert
Does anyone have pics of the extended wheelbase lifts?
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
