best 4 inch lift kit? - JeepForum.com
post #1 of 13 Old 03-15-2010, 09:55 AM Thread Starter
erhenriques
i am looking for a good 4inch lift kit for my 2006 tj with a 4 cylinder engine. i dont want to go to cheap but i dont do much serious off roading. i am confused with what the difference is with a long arm kit? what is better about the long arm
erhenriques is offline
post #2 of 13 Old 03-15-2010, 10:03 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
LA kits ride better.Longer control arms.Why go with the best if you don't do much serious stuff? RC works well.
TheBoogieman is offline
post #3 of 13 Old 03-15-2010, 10:27 AM
Ironwind1972
There are pro's and con's to every lift. Do a lot of research. Long arms ride better, but are more prone to your control arms hanging up on larger rocks, require more modifications to the vehicle, and can be very pricey. Short arms ride stiffer, stray further from the factory control arm angle design, require less modifications and cost less. My opinion, the currie 4" is the best short arm, I've had two RC short arms and regretted them both. I run a Currie 4" now and am very impressed with it's design, quality, and strength. RC's X series is a cheap imitation of the Currie design. You get what you pay for when it comes to lift kits, so buyer beware.
Built to explore.
Ironwind1972 is offline
post #4 of 13 Old 03-15-2010, 10:36 AM
RubiconRazorbac
RubiconRazorbac's Avatar
For me it was disappointment when I bought something I thought was "good enough", then had to spend MORE money to get something that would be reliable and perform as advertised.
OmanJeep's advice to go with quality and cry once, or go cheap and cry many times comes to mind...
Originally Posted by Ironwind1972 View Post
There are pro's and con's to every lift. Do a lot of research. Long arms ride better, but are more prone to your control arms hanging up on larger rocks, require more modifications to the vehicle, and can be very pricey. Short arms ride stiffer, stray further from the factory control arm angle design, but require less modifications and cost less. My opinion, the currie 4" is the best short arm, I've had two RC short arms and regretted them both. I run a Currie 4" now and am very impressed with it's design, quality, and strength. You get what you pay for when it comes to lift kits, so buyer beware.
X2
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #5 of 13 Old 03-15-2010, 10:40 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Clayton Off-Road, Gen-Right or Poly Performance long arm kit with 4" AEV Progressive or Old Man Emu springs, with outboarded rear shocks.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 13 Old 03-15-2010, 12:10 PM
never monday
read longarm basics
never monday is offline
post #7 of 13 Old 03-15-2010, 12:20 PM
TheBoogieman
Disturbed
Big boys don't cry.
post #8 of 13 Old 03-15-2010, 12:23 PM
GriffTatum
1992 MJ Comanche
Ive ran Rough Country from the beggining (of getting a lift) not offroading, and it's done we well. I had a lot of issues with flex so i got sway bar quick disconnects, and in my opinion, that's when you get the full value out of your suspension.
GriffTatum is offline
post #9 of 13 Old 03-15-2010, 12:27 PM
Unlimited04
FYI, RC isn't near the quality of Currie, AEV or Clayton Off-Road, etc. Not even same ballpark. Also disconnecting sway bars is NOT how you get "full value out of your suspension". Replacing the front and rear sway bars with either an Anti-Rock or dual rate sway bar system IS.
Useful Write-Ups:
Funny:
post #10 of 13 Old 03-15-2010, 12:52 PM
RubiconRazorbac
Big boys don't cry.
OK, well maybe just at the end of Old Yeller
2003 TJ Rubicon:
2017 JKU Rubicon:
post #11 of 13 Old 03-15-2010, 01:11 PM
Unlimited04
I cried in "Gone in 60 Seconds". They really trashed a beautiful Shelby
Useful Write-Ups:
Funny:
post #12 of 13 Old 03-15-2010, 01:30 PM
Jeepzcb09
get the RC 4in "X" kit, im ordering it Wensday, so if this thread is still around ill let you know
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #13 of 13 Old 03-15-2010, 02:04 PM
Grindahl
Most people on here will suggest what they have or what they did. Nothing wrong with it, they know it works.
1) Are you doing the install yourself?
2) Find a retailer you can trust and get their input. They do it for a living day in and day out. A good one can even suggest changes to meet your needs based on your location and what you do.
For me, I called David at Northridge4x4. He knows my area and was able to go over all aspects of short vs. long, kits vs. hybrids, etc. etc.
Again, this is what I did... you alone can decide what you will do.
Grindahl is offline
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 09:36 AM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
Right rear tire extends inch farther out than left after 2 inch lift. blang158 TJ Wrangler Technical Forum 9 07-05-2006 12:15 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 10:16 AM
