Best 4.0 Tuner Programmer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Best 4.0 Tuner Programmer
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Northridge4x4 - Superchip Flashcal In Stock
Unread 01-09-2011, 05:35 PM   #1
JeepnBlake
I'm looking for some info on programmers for my 04.
A new cam and a few other performance mods (stroker) are likely for the future so I would like to have a plan to keep the AFR in spec for when the time comes.
I've seen hypertec and superchips etc, are they any good? I've heard good things about the split second tuner as well.
All opinions welcome
-Blake-
WTB: Currie Front Uppers CE-9102, Currie Double JJ Rear Trac Bar CE-9120R, & Currie Trac Bar Bracket CE-9121N, Or Currie Rear TB with Bracket Kit CE-9123N
Build Thread: http://www.jeepforum.com/forum/f22/j...thread-985907/
OEM Fog Light Connectors, Conversions, and Extension Info:http://www.jeepforum.com/forum/f20/o...ngler-1008928/
JeepnBlake is online now   Reply With Quote
Unread 01-09-2011, 05:39 PM   #2
Anytimeanytrail
I just put the EDGE chip and throttle body on my jeep. I love the turnout. Definitely made a huge difference.
**2002 TJ X- See <-- for details
**'09 Honda Foreman 500- 27" Executioners, 12" STI's, custom LOUD radio, cooler/seat, 6000k HID's Hi/Low, jet kit..
Anytimeanytrail is offline   Reply With Quote
Unread 01-09-2011, 06:05 PM   #3
freeskier93
"Generation Dead"
freeskier93's Avatar
Chips, cold air intake, throttle body spacers, all just a waste of money (snake oil). If you want improvement do a regear, do an engine swap, or buy a new car. These 2.5/4.0L engine are not meant to be tuned, they were put in Jeeps for their good low end torque offroad, not to red light race.
freeskier93 is offline   Reply With Quote
Unread 01-09-2011, 06:33 PM   #4
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
the only chips that will accommodate the mods you speak of are the Unichip and the SplitSecond FTC-1. Both are piggyback's. The FTC-1 is a splice and cut wire type & comes with its own MAP sensor. The Unichip is a plug-n-play tuner. Both must be tuned via a dyno shop for your specific mods. All other chips are a complete waste of money and cannot be tuned for a custom engine setup.
Unlimited04 is offline   Reply With Quote
Unread 01-09-2011, 06:35 PM   #5
joe_jeep
glfwda #6624
joe_jeep is offline   Reply With Quote
Unread 01-09-2011, 07:04 PM   #6
nickeagle
I mad my own map sensor adjuster. I dont know if you can with yours being a 06. It cost me 15 bucks and works! You will need a Air/Fuel gauge to tune it though.
1998 wrangler 4.0
D44 front truss 3 link crossover+assist steering
D60 4.88 spool
ucf ultra high clearence skid + engine skid
37x12.50/17 KM2 K.O.R.E beadlocks
nickeagle is offline   Reply With Quote
Unread 01-09-2011, 07:08 PM   #7
JeepnBlake
That's what I was thinking, thanks.
-Blake-
Unread 01-09-2011, 07:13 PM   #8
Unlimited04
how?
Unread 01-09-2011, 07:35 PM   #9
flatlander757
Until you do build a stroker, it's all a waste of money.
Even when you have a stroker, if you don't have the right gears you'll never be putting down the power and torque at the time you need it.
What tire size to you run/plan on running?
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote
Unread 01-09-2011, 08:18 PM   #10
freeskier93
"Generation Dead"
Originally Posted by joe_jeep View Post
Care to explain?
Unread 01-10-2011, 06:31 AM   #11
Pillswoj
Care to explain?
The Original poster asked about tuning a Modified Cam / Stroker. You replied with the Same old BS about about CAIs, chips and spacers on Stock engines.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
Unread 01-10-2011, 07:35 AM   #12
never monday
how?
put a pot in the signal line and adjust to get the AFR you want. It's a bad idea IMHO
Get Savvy
never monday is offline   Reply With Quote
Unread 01-10-2011, 07:55 AM   #13
Unlimited04
thats what i've heard....can't imagine it would too well with Jeep's stubborn OBDII...besides AFR changes depending what loop you're in...
Unread 01-10-2011, 09:53 PM   #14
freeskier93
"Generation Dead"
No, the OP asked about tuner chips, I gave my opinion. Most plug in chips are a load of crap, but as Unlimited04 there are some real chips that are good, but require dyno tuning.
Specifically the OP gave the name "Superchip" which is one of those crappy one that don't do anything.
Unread 01-11-2011, 12:15 AM   #15
lukesdiesel
Hows the Unichip?
04 Wrangler Sport, 4.0 I6, 5spd Trans, 4" Skyjacker Lift, 33" Mud Grapplers, D44 3.73's with Detroit Locker
lukesdiesel is offline   Reply With Quote
