Best 2.5" for my needs? - JeepForum.com
post #1 of 1 Old 07-17-2010, 10:13 PM Thread Starter
kennyboobear
So am finally getting around to buying my lift, and am dead set on a 2.5" I plan on weighing it down a good bit (hard top, bumpers, winch, full corners, rockers, flat fenders + gear inside) and running 33s or possibly 35s, either at 10.5 wide, with some trimming of my rear full corners.
The impression I've been under is that the OME 2.5" HD kit would be my best bet as it's designed to be weighed down a good bit, and rides quite well under load. Opinions? Pictures? Anyone done this themselves?
I'm trying to keep it as low as possible to retain my DD capabilities, while still maintaining a well built, and rugged rig. Any recommendations of other lift kits? Would like to make sure I don't drop 800$ on a 2.5" lift that I end up hating, so yea, thanks in advance for any input.
SILVER JEEP CLUB MEMBER #46
Get
Originally Posted by GraKee99 View Post
Driving on snow is a lot like sex, it's a lot of fun but if you don't pay attention, you can really mess up someone's rear end.
Originally Posted by Gene Mooneyham
Not to burst your bubble, but California gets worse every year. Liberals, and illegals have ruined any chance California had to get turned around, it's a sinking ship.
kennyboobear is offline
fenders , tj , wrangler , lift , suspension , suggestion , help , advice
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 12:54 PM
E-brake only stops the jeep when going in "R" or "N", but not "D" Gabe TJ Wrangler Technical Forum 4 02-27-2010 07:09 PM
mettalic "clank", "pop", "squeak" txpedro TJ Wrangler Technical Forum 2 03-21-2007 06:45 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 02:24 PM
