best 2-2.5in suspension lift - JeepForum.com
post #1 of 35 Old 12-14-2010, 12:34 PM Thread Starter
shamrock111
i have been looking to buy a small lift for my 2002 wrangler sport and would like input on which ones are awesome and which ones are bad
Thanks!
Tom
shamrock111 is offline
post #2 of 35 Old 12-14-2010, 12:35 PM
NotURMailman
What do you want to do with the Jeep?
Offroad?
DD?
What type of on-road ride quality do you expect?
How long do you plan to keep it?
Will you ever want more lift?
How much do you expect to spend?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 35 Old 12-14-2010, 01:03 PM
2006_Sport
Stay away from the RC 2.5.
The best 2-2.5 inch lifts are either the OME 2.5 or the BDS 2 inch. I have the BDS and love it, rides great. The OME is nice too.
2006_Sport is offline
post #4 of 35 Old 12-14-2010, 01:08 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
OME, Rancho, RCD, BDS. in that order.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 35 Old 12-14-2010, 01:09 PM
2006_Sport
OME, RCD, BDS. in that order.
What's RCD again? I always forget.
post #6 of 35 Old 12-14-2010, 01:13 PM
mightydog78
RCD lift kits for Chevy, Dodge, Ford, Jeep, Toyota
i keep thinking i was going to get the RC 2.5, but it seems like everyone on JF is split about that setup..
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #7 of 35 Old 12-14-2010, 01:15 PM
Unlimited04
dont forget Rancho too.
Useful Write-Ups:
Funny:
post #8 of 35 Old 12-14-2010, 01:58 PM
IslandTJ
This .
Now Jeeping in Oregon
IslandTJ is offline
post #9 of 35 Old 12-14-2010, 02:01 PM
Varnish
Varnish's Avatar
I'd throw a 2" RE budget boost on and be done with it. No need to get fancy at that height.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #10 of 35 Old 12-14-2010, 02:22 PM
badtux
I disagree:
1) The OEM springs sag rapidly with the spacer lift especially in the front because they overcompress because RE doesn't provide front bump stop extensions. By 40K miles my springs were sacked out.
2) The RE budget boost shocks suck the big one. As in, washboard roads make the back end of your Jeep dance all around, and your fillings vibrate out. You'll end up replacing them with BD or OME shocks (which handle washboard *much* better), so why not just go with the BD or OME lift in the first place?
The budget boost is better than nothing if you're not sure how much lift you're going to eventually put on and are intending to put on a real lift within the next 20,000 miles or so, but if you're sure you're going to stop at 2.5 and 33" tires (because, say, it's a daily driver, or because you don't want to mess up the extended warranty, or because you don't want a high-COG Jeep), I say go ahead and go with the OME or BD.
badtux is offline
post #11 of 35 Old 12-14-2010, 02:44 PM
thisgardengrove
What's wrong with the Rough country 2.5 lift?. i just purchased their 2.5 long arm kit and have heard good things about their product. Was recommended to me by a freind who is a avid offroader and builder
thisgardengrove is offline
post #12 of 35 Old 12-14-2010, 02:47 PM
2006_Sport
2.5 inch lift on long arms? Have fun with that in the rocks.
post #13 of 35 Old 12-14-2010, 02:49 PM
Cavitation
I dont see anything wrong with the RC 2.5. But the 2.2 shocks are a bit on the stiff side.
Cavitation is offline
post #14 of 35 Old 12-14-2010, 02:53 PM
asknight
As one who purchased (and then spent more to make it right) the RC 2.5" kit, I would choose another kit if I had it to do all over again.
The 2.2 shocks are way too stiff for a lightweight TJ. Swaybar disconnects are not included in the kit, so you will not get the amount of flex advertised in the kit unless you spend more to add them. A rear trackbar bracket isn't included, and is required if you want proper handling, bushing wear, and your axle centered under the Jeep. A front adjustable trackbar isn't included, and is required for the same reason as the rear trackbar bracket. The tcase drop included with the kit is the height of those intended for a 4" suspension lift, so you'll more than likely have just as many vibes after you add it as you did before if you don't cut the plastic pucks in half. A handful of washers 2-4 per skid bolt is the most common solution to eliminate vibes.
asknight is offline
post #15 of 35 Old 12-14-2010, 02:56 PM
thisgardengrove
are you talking about the basic 2.5 kit or the long arm kit? and why would would it be a bad on the rocks? it doesn't take the arms much further past the stock locations. the long arm kit comes complete.
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 09:19 PM
4in suspension lift + 2in shackles + 2in body lift = 35in tires? snou52 YJ Wrangler Technical Forum 24 03-22-2009 06:21 AM
i have a 4"suspension lift and my 35's fit fine why do i need a body lift?? bumblebee92gt TJ Wrangler Technical Forum 6 01-20-2005 07:50 AM
