Bent differential is popping and grinding - JeepForum.com
post #1 of 15 Old 07-22-2010, 09:31 AM Thread Starter
lemonsigmapi
I have a stock TJ 2000 sport dana 30 front axle. So I have had some popping and grinding from my front end after driving for 20 plus minutes. I took it to a shop where the guy said I had a bent front diff. He then tried to say he found a USED ONE FOR $1700 (yes seventeen hundred). The Jeep doesnt pull, vibrate or anything weird at all. I really think it is something else much more simple. Wouldnt I have other symptoms? Thanks
lemonsigmapi is offline
post #2 of 15 Old 07-22-2010, 09:53 AM
roundlitefan
roundlitefan's Avatar
Well, first of all, people will practically pay YOU to get a TJ D30 with 3.07s out of their yard, so whatever you do, don't pay that clown $1700 for one.
Should be able to score one from CL for $100 maybe less.
It is pretty simple to install yourself also.
If the sound has you worried you should start looking on Craigslist for a replacement D30.
If it were me, I would drive it until it grenades, and then have the spare sitting there ready to swap in.
People here will tell you to get a cherokee hi pinion D30 as a swap. that is fine, it is an upgrade, but if you have no plans on going to bigger tires, with as cheap as they are, I would personally just always keep an extra factory D30 around to swap in.
roundlitefan is offline
post #3 of 15 Old 07-22-2010, 10:15 AM
theducksguts
This
You can do this job it isn't difficult. Just hand tools, breaker bar, PB blaster Jack stands, and a floor jack. One person job, extra hands are helpful. Should be able to do this in about a day.
post up if you need anything/have specific questions.
Check out my
theducksguts is offline
post #4 of 15 Old 07-22-2010, 12:14 PM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
I want some of whatever that guy was smoking... That d30 would need trusses, locked, loaded, hp, with chrome moly shafts to be MAYBE be worth half of what he was telling you... Do yourself a favor and never go back to that thief.
Take the advice of the other guys replying and just find a used one and spend an afternoon swapping it out.
-Dave
AustinCJer is offline
post #5 of 15 Old 07-22-2010, 12:32 PM
mdm
Farm Wheeler
...If it were me, I would drive it until it grenades, and then have the spare sitting there ready to swap in...
Where do you plan on being when it "grenades"? Pulling out of your garage? Maybe in the Home Depot parking lot? How about ten miles from the trail head on a one way trail with eight other rigs behind you? How would you feel about it happening when you are doing 70 mph on the Interstate?
How are you going to drag that spare D30 around with you while you wait for your's to fail? Strap it to the roll cage? That could work in the summer but you'd probably need another option in the winter when the top goes back on.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 15 Old 07-22-2010, 03:04 PM
pwcracer
Too bad you live so far away, I have my old dana 30 sitting in the driveway about to be hauled away for scrap.
For $1700 you could get a new Dana 44
pwcracer is offline
post #7 of 15 Old 07-22-2010, 07:07 PM
roundlitefan
Who pissed in your cornflakes mdm? You just love picking e-fights don't you?
I said if it were ME, that is what I would do. You go do whatever you would like to do.
I also offered the OP some useful advice, unlike you.
post #8 of 15 Old 07-22-2010, 07:10 PM
LJameson
What exactly are you getting for 1700? If he's buying the axle, regearing it to match, taking out the old one and putting it back in, I wouldn't say he's asking too much.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #9 of 15 Old 07-22-2010, 08:13 PM
dcope17
True, but why put $1700 worth of work into an axle that you can just replace for a lot less.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #10 of 15 Old 07-22-2010, 09:42 PM
LJameson
I agree, you can do it for much cheaper. But all things considered, if you didn't know how to do it yourself that price isn't out of the ordinary.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #11 of 15 Old 07-23-2010, 09:31 AM
dcope17
You're right and no shop will buy a used axle and put ot on without going through it...
dcope17 is offline
post #12 of 15 Old 07-23-2010, 10:06 AM
extsp2
i agree. if that were here in our shop we'd go through the diff with fluid, seals, most likely bearings and probably new ujoints in the axles. adding up parts, misc. and labor i don't think that's too bad of a price. but you can save a ton of money if you try it yourself.
extsp2 is offline
post #13 of 15 Old 07-23-2010, 10:24 AM
roundlitefan
used D30 ~$100 (probably free, but for the sake of arguement)
D30 rebuild kit ~$125
2 new u-joints (if needed) ~$40
gear oil and RTV ~$20 (being generous here)
total parts = $285
$1700-$285 = $1415
You feel that $1400 is a reasonable labor cost to check out a D30 and replace the fluids and u-joints?
That is 20 hours labor if you charge $70/hour.
Is 20 hours labor for that reasonable?
Granted I have never rebuilt an axle, but you aren't even talking about setting up gears, just replacing bearings and u-joints.
post #14 of 15 Old 07-23-2010, 10:46 AM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
For a point of reference:
Dana 44 Axle Assemblies
"Factory MOPAR Front Axle with OE Trac-Lok, & your choice of
gear ratio $1750.00" - Thats a Dana 44
-Dave
post #15 of 15 Old 07-23-2010, 11:02 AM
extsp2
it depends how deep they were going into the diff which we don't know. all we know is that he said a used diff for $1700. we don't know if that was just for the part or for the part and ring and pinion set, ball joints, ujoints, wheel bearings brake pads and rotors, etc.......i think we're all just assuming different scenarios without all the info.....don't even know the hourly rate of the shop....it can vary from $50 to $100 an hour......
i was thinking all of the above would be done for that money........
extsp2 is offline
popping , grinding , axle , bent , replace , replacement , d30 , dana 30 , TJ
popping and grinding noise in 4h and 4l but fine in 2h RockHill YJ Wrangler Technical Forum 4 11-20-2008 07:10 PM
Front differential grinding elton YJ Wrangler Technical Forum 3 10-03-2008 11:14 AM
differential popping TimTJ TJ Wrangler Technical Forum 5 07-04-2005 02:39 PM
Rear differential popping usetobejeeper TJ Wrangler Technical Forum 4 06-17-2005 08:05 PM
NP231 Popping/Grinding YellowJeep YJ Wrangler Technical Forum 5 01-06-2005 11:36 AM
