Bent D30 Axle Housing...anyone else? - JeepForum.com
post #1 of 9 Old 07-03-2006, 08:13 PM Thread Starter
Scafone
Scafone's Avatar
I found a hidden hole in a grassy trail a while back, which nearly removed my front axle for me. Yeah, ouch. Fortunately, I was able to drive it out and home. I repaired the mangled bracket and replaced a control arm, but am still realizing the other damage as I have time to look into it. Also bent the track bar.
Anyways, I need to fix it, so 2 questions:
1. Can a bent housing be straightened? The passenger side only.
2. What sort of damage can result from using it as-is? ...inside the differential, hub bearing?
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline
post #2 of 9 Old 07-03-2006, 08:24 PM
stogie25
stogie25's Avatar
Nice signature, few greater truths have ever been told.
If you have to ditch the axle, consider a hp D30 from a cherokee.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #3 of 9 Old 07-03-2006, 09:52 PM Thread Starter
Scafone
Scafone's Avatar
Thanks. I'm a bit of a fundamentalist. A God-fearing, USA-loving, gun-toting, right-wing fundamentalist.
Anyways, I think I'll be going for a junkyard replacement to keep the cost down if it comes to that.
--Thomas Jefferson
Scafone is offline
post #4 of 9 Old 07-03-2006, 11:28 PM
Achped
Ahhh, one of those guys.
Me too
I've never heard of anyone re-straightening an axle, but I surely wouldn't want a re-straightened axle on my Jeep when I'm 150 miles away in the middle of a forest!
Achped is offline
post #5 of 9 Old 07-03-2006, 11:43 PM
ffej
Axle housings are straightened all the time. That said, like mentioned, an upgrade to the HP30 wouldn't be a bad idea (though it'll cost more than straightening your current axle, new gears, bearings and setup).
ffej is offline
post #6 of 9 Old 07-04-2006, 01:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Me too
You really need to go to a factory that makes axle shafts from scratch. After they heat treat them, the flanges have so much wobble to them that not one would ever be useable, that is until they put them in a press and straighten them out.
BTW- in order to re-straighten a housing, it has to have been straightened at least once already.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #7 of 9 Old 07-04-2006, 07:44 AM Thread Starter
Scafone
Scafone's Avatar
I wouldn't want a restraightened axle shaft either. I'm not even sure I want a restraightened housing. I'm only referring to the axle housing here...specifically the passenger side axle tube. I am assuming my shafts are ok, since the Jeep drives about the same as before, but is that even possible? Using a straight-edge, the pass. side axle tube is clearly curved up. I suppose I just need to open the diff, pull the axles and inspect. I'm about to start looking for a replacement, but just want to know how much damage it would do to drive it this way in the mean time. In case I end up with an empty housing, I don't want to trash the inners in this one.
--Thomas Jefferson
Scafone is offline
post #8 of 9 Old 07-04-2006, 11:58 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
For the record, you are already driving on straightened axleshafts front and rear. But, the easiest way to find out if you are damaging anything is to look at the shaft where it exits the housing inside the knuckle. If it's not rubbing right there, it will be fine.
I've taken a lot of front ends apart from salvage yards and only one was bent enough from a wreck that I couldn't easily pull the shafts. That one clearly showed the axles rubbing on one side of the tube where it exited the housing.
I am Savvy
post #9 of 9 Old 07-04-2006, 08:31 PM Thread Starter
Scafone
Scafone's Avatar
Thanks for the info! Much appreciated. Looking quickly, I didn't see any rubbing at the outside, but I'll give'r a good inspection soon.
--Thomas Jefferson
Scafone is offline
Bent D44 Front Axle housing taftech TJ Wrangler Technical Forum 9 02-09-2010 11:53 AM
Bent lower control arm...bent axle? fang_x TJ Wrangler Technical Forum 18 01-04-2010 03:26 AM
Anyone have experience with a bent axle housing/tube? Imped TJ Wrangler Technical Forum 9 02-14-2009 04:39 PM
Bent Rubicon Axle Housing 514rem TJ Wrangler Technical Forum 3 03-16-2008 08:54 PM
Got my TJ D44 axle housing and need help Lud04X TJ Wrangler Technical Forum 16 09-15-2006 03:17 PM
