Benefit of Currie anti rock over quick discos? - JeepForum.com
post #1 of 38 Old 01-04-2010, 11:43 PM Thread Starter
WILLY348
Well i was thinking about posting this in my last thread, but i figured it might be better to get a new topic. So, what is the advantage of having the currie anti rock sway bar system over a set of quick discos?
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra
WILLY348 is offline
post #2 of 38 Old 01-04-2010, 11:47 PM
Imped
Imped's Avatar
You don't have to disconnect the links. And your sway bar adds a level of stability, but in stock form it's far too stiff. That's why you disconnect it. The AntiRock gives you the added stability without impending on articulation. You'll get a bit more body roll on the road but it's nothing major.
OlllllllO
IndyORV
Imped is offline
post #3 of 38 Old 01-04-2010, 11:52 PM Thread Starter
WILLY348
So would this not be the best ideal setup for a daily driver?
WILLY348 is offline
post #4 of 38 Old 01-04-2010, 11:56 PM
97casteeltj
97casteeltj's Avatar
depends on your budget and the practicality of spending that much, i can say while my TJ was a DD i had disco's and IMO disco's are disco's they are all going to do their job while connected and all are going to be a PITA sometimes while taking them off on the trail and then putting them back on. with that said, if you have the money i would opt for the anti-rock or a comparable item.
BTW, i ran JKS Quicker Disco's and RE Gen II disco's and out of those two, i would go with the RE Gen II again (but i don't run a anti-swaybar anymore )
-John
needing a new rig....
97casteeltj is offline
post #5 of 38 Old 01-04-2010, 11:56 PM
Imped
Imped's Avatar
It's certainly not bad. I prefer a little less body roll on the road for now. But if someone gave me an AR, I'd certainly take it.
OlllllllO
IndyORV
Imped is offline
post #6 of 38 Old 01-04-2010, 11:57 PM
06WranglerX
I have an anti rock on my jeep and use it as a DD, its fine I just take my time in turns and drive it like its a lifted jeep.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #7 of 38 Old 01-05-2010, 12:40 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My TJ is a daily driver and my Antirock is set to its loosest setting. Sure there's a bit more body roll than a sports car would have but it's no big deal. I drive it like a Jeep and not a 350Z so it's fine for me.
Offroad, it's far better than either being completely disconnected or having the front swaybar connected as the front & rear suspensions can work together instead of fighting each other as they will when the antiswaybar(s) are disconnected.
Never disconnect or remove the rear antiswaybar.
Getting
Jerry Bransford is online now
post #8 of 38 Old 01-05-2010, 12:48 PM Thread Starter
WILLY348
Thanks for the input guys, im seriously considering the Currie sway bar
Also.. what exactly is "body roll"?
WILLY348 is offline
post #9 of 38 Old 01-05-2010, 12:52 PM
VanBCguy
Don't just consider it. Buy it. It's one of those no-brainer Jeep purchases that once you buy it and run it (on and off-road), you'll see, feel and know the worth. It's in the top 3 of the best add-ons that I've ever done to my heep.
VanBCguy is offline
post #10 of 38 Old 01-05-2010, 12:52 PM
RubiconRazorbac
RubiconRazorbac's Avatar
For a very basic example drive a go-kart, then drive a van. Take a pretty sharp corner in both. That'll show you body roll.
That's not EXACTLY the best definition, but it'll work.
EDIT: Or better yet, go ahead and disconnect your anti-swaybar and drive around the block (carefully).
Your shaft isn't long enough to handle that kind of droop...
My build thread:
RubiconRazorbac is offline
post #11 of 38 Old 01-05-2010, 12:56 PM
2005X
with my antirock im on the 2nd most agressive setting, i have lost some flex but gained traction, i can really tell the difference in offcamber moments.
2005X is offline
post #12 of 38 Old 01-05-2010, 01:11 PM
SantaAnaSlim
2004 XJ Cherokee
My TJ came with the antirock. I drive it to and from work and it's great and living in Orange county anywhere I go wheeling is a 2+ hour drive. The antirock is on it's softest setting and it drives fine and it's lifted 5" on 35s. It drives a hell of a lot nicer than my YJ ever did, though that's not so much the sway bar. From what I understand it actually helps your offroad traction by putting some pressure on your front end.
SantaAnaSlim is offline
post #13 of 38 Old 01-05-2010, 01:32 PM
RubiconRazorbac
Check out the thread in the link below. It's an oldie, but it's a goodie.
http://www.jeepforum.com/forum/f27/m...i-rock-132003/
My build thread:
post #14 of 38 Old 01-05-2010, 09:45 PM Thread Starter
WILLY348
Alright.. so.. now i need to start looking at priceing.. is there any single site out there cheaper then quadratec at $299.99? Also.. is there any thing that needs to be modified on my jeep to install this.. because i don't have any sort of grinders/cutting tools.. just simple hand tools. I saw in one of the reviews from the previous post that they had to modify their bumper or something to get the torsion bar to fit correctly
WILLY348 is offline
post #15 of 38 Old 01-05-2010, 10:06 PM
2005X
i bought mine through Northridge4x4 Jeep Parts Online Store they have free shipping for anything over $100. we also had to cut a notch into my bumper
2005X is offline
Currie Anti-Rock or discos on stock TJ? Dirty Backroads TJ Wrangler Technical Forum 46 02-24-2015 06:48 AM
currie anti rock pumpman55 TJ Wrangler Technical Forum 18 12-03-2009 01:33 PM
Currie Anti-Rock s1edneck700 JK Wrangler Technical Forum 2 04-09-2009 06:09 AM
currie anti rock jeepwcrazy TJ Wrangler Technical Forum 4 08-26-2008 07:58 AM
Currie Anti-rock JT29 YJ Wrangler Technical Forum 10 02-15-2005 08:31 PM
