Bellhousing top bolt sizes - JeepForum.com
post #1 of 7 Old 03-26-2009, 10:33 AM Thread Starter
tj03clipper
98 4.0 5sp. anyone know the size bolts on top side of bellhousing...the two reverse torx bolts...need the thread size their a M10 bolt but having a hard time getting thread size correct.
tj03clipper is offline
post #2 of 7 Old 03-26-2009, 11:02 AM
bnine
That is a hard find. Trying to get a metric thread into a 3/8's course hole is always a bich
bnine is offline
post #3 of 7 Old 03-26-2009, 11:09 AM Thread Starter
tj03clipper
No.. these that came out are metric
post #4 of 7 Old 03-26-2009, 11:23 AM
diy4x4
2007 MK Patriot
Are you sure its a M10? My 97 parts book says the bolts on the top of the bell housing are M12x1.75x50
diy4x4 is offline
post #5 of 7 Old 03-30-2009, 10:48 AM
bnine
Not a chance. Wrong bolts altogether..
I've hung close to a dozen 4.0's and 4.2's of engine stands. Everything from 82-03. I've always used standard bolts. I'm supprised to hear you have metric in there.
bnine is offline
post #6 of 7 Old 03-30-2009, 12:33 PM
diy4x4
2007 MK Patriot
I have no clue what's actually there. I was just going off the 97 parts book, Hex Head M12x1.75x50. But you know how these things go. My body tag says I drive an automatic. If thats true, its the most labor intensive auto I've ever driven. Lol. P.S. the 97 is the most hodge-podged Jeep in the TJ series. I don't doubt anything with mine anymore.
diy4x4 is offline
post #7 of 7 Old 03-30-2009, 01:51 PM
bnine
No worries. The top bolts are inverted torx 99% of the time, and a 12mm is basically a half inch bolt. Those are used on the bottom of the inspection plate for sure (the 18mm on both nut and bolt ones), and maybe somewhere on the side, but definately not on the top. Those ones are tiny in comparison to a 12mm.
bnine is offline
Bellhousing bolt epidemic? Mean Max YJ Wrangler Technical Forum 0 07-05-2009 06:52 PM
tranny bellhousing bolt size?!?!?!?!? StuckInMud94 TJ Wrangler Technical Forum 0 06-18-2009 03:19 PM
Bellhousing to Engine bolt JeepNWilly TJ Wrangler Technical Forum 2 02-18-2009 01:38 AM
bolt shot threw bellhousing.. drenmaster j TJ Wrangler Technical Forum 7 12-09-2004 01:11 AM
torx bellhousing bolt size mhmmofr0 YJ Wrangler Technical Forum 5 10-27-2003 07:20 PM
