Beginning of death wobble (axle video)
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
Check out this video. Its not the worst i've had, but it was shaking pretty good. Time to tighten up the bolts and check the toe in.
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/aXN8YtSRm6k&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/aXN8YtSRm6k&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
#2 |
Recon death squad
dude you have chassis videos for all occasions. I'm hooked
and I was driving down the highway (I-80 in PA) and they stripped the asphalt down so that it was all rough and choppy. I ended up with something like the onset of DW and it scared the **** out of me. It was so weird
SOLDSilver 02 TJ Apex Edition. "Pandora" 3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff IndyORV |
#3 | |
X2 i love the chassis video's
Want to STOP? JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits My Goodyear tire experience |
#4 |
x3, the chassis videos rock. you must have a sweet camera and camera mount to be able to do that with no vibes.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#5 | |
http://www.youtube.com/watch?v=nLZaDvRHwhs |
#6 |
Do'h, its getting worse every day. I had to pull off the freeway today to get it to stop shaking violently (way worse than the video). It probably started like in the video at least 5 times on a 20 min drive. My tires are near the end of their life so i need to decide if i should get new wheels and tires (33s), or balance these and run them another couple thousand miles. I was trying to attempt an alignment last night, but its too tricky by myself.
#7 | |
Recon death squad
Bungee cord a broomstick to each tire. Makes measuring much much easier
#8 |
Great video ! how bad can it get? I have never expierenced it (yet)?
Jeff |
#10 | ||
Its weird because there was only a slight hint of it when i first put the lift on. After about 500-1000 mi its WAY worse and happens on every drive (to an extent). I suspect tire balance is the main cause because it happens at about 50-60mph, and never under that. Its real similar to a tank slapper on a sport bike. Maybe the rc dampener needs to be a bit stiffer? |
#11 |
Recon death squad
Yea you can hook the tape measure on the stick and get an even and precise measurement front and back for your toe-in. Just make sure the broomsticks are at the same height on both tires. So you have an accurate measurement EDIT: added pic for reference ![]()
SOLDSilver 02 TJ Apex Edition. "Pandora" 3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff IndyORV Last edited by Apex; 06-03-2009 at 11:55 AM.. |
#12 |
I got DW with 35x14.5 boggers, holy crap. I had experienced it before with 31's, but with the boggers I thought I was done for. I had a broken track bar and was trying to limp back to the cabin from the trail, it was horrible.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA |
#13 |
Thanks!! For some reason i was thinking you meant to stick the broom sticks towards the other tire! I thought "thats one hell of a bungee cord to hold them out like that, maybe a ratchet strap!". Its much more clear now.
![]() Is that an air line hooked into your sway bar? got any info on that setup? |
#14 |
I feel your pain jgorm.... I just resolved mine after it reoccurring several times over the last year....
It took.... Replaced old worn MTRs that would not balance.... Went away... Replaced SS just in case since I was moving up to 33s from 31s... Came back, reset the toe in on my alignment, it went away.... Came back... Replaced track bar, replaced track bar hardware since 4 Wheel Parts gave me the wrong bolts and re-tightened it twice.... Went away... Came back after a while with my current 3.25" of lift.... Replaced my lower CA with some Rusty's adjustable arms and added back 3/8" length... Gone again.... Still have not done a rotor turning/replacement or replaced stock brake pads yet... I am sure that will come sometime in summer... DEATH WOBBLE SUCKS
JEEPLESS... :( |
#15 | |
Recon death squad
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
