Beginners suspension lift - JeepForum.com
post #1 of 16 Old 07-21-2011, 05:57 PM Thread Starter
Blakecognata6
i have a 2005 wrangler and i am looking for a suspension lift. i have found one that i am interested in for 483 dollars. its a skyjacker lift. (first one on this page>>http://4wheelonline.com/jeep/Skyjack...s.23917.261171
i don't know if i am making the right purchase. i am someone who will OCCASIONALLY take this on a small trail, no really extreme off roading. just looking for some opinions to see if this is a good beginners suspension lift.
Blakecognata6 is offline
post #2 of 16 Old 07-21-2011, 08:22 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Bump to the top after a delay approving it.
Getting
Jerry Bransford is offline
post #3 of 16 Old 07-21-2011, 08:31 PM
Jay12
What size tire do you plan on running?
Jay12 is offline
post #4 of 16 Old 07-21-2011, 10:02 PM
bstew417
For a beginners lift, I would stick with a 2-2.5" lift. Something like Old Man Emu will ride well on the street and not require transfer case drops, slip yoke eliminators, and other modifications along with it.
Black '02 TJ 33x10.5 KM2s Dana 30/44 Aussie/Ox RC 2.5" coils/Bilstein 5100s
bstew417 is offline
post #5 of 16 Old 07-22-2011, 12:04 AM Thread Starter
Blakecognata6
Well I was hoping to run 33's..
post #6 of 16 Old 07-22-2011, 05:33 AM
FXSTCHEWY
FXSTCHEWY's Avatar
Zone 3" should work fine.
"To preserve liberty it is essential that the whole body of the people always possess arms and be taught alike, especially when young, how to use them." -- Senator Richard Henry Lee, 1788
- Wannbe Old Guy Jeep Club Member
-06' Unlimited,3" BDS/Zone,American Eagle 185's,Cooper St's 33x12.5's,Ramsey 8.5,Tomken,Jeeperman,Warrior,Tuffy, Pioneer.
FXSTCHEWY is offline
post #7 of 16 Old 07-22-2011, 06:42 AM
j_niko
2009 JK Wrangler
With the proper backspacing of the rims, you can run 33s with a 2.5" lift.
M wife's 2000 has a 4inch Skyjacker (PO installed) and it rides extremely rough and likes to wander a bit.
I it was me, I would consider Rough Country's 2.5 with the new n2.0 shocks or Zone's 3".
I will be doing one of those two in the very near future on my 97.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #8 of 16 Old 07-22-2011, 08:01 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
33's are fit in two common ways on TJ's:
1. 4" suspension lift, with 2" bumpstop extensions in front and 2-2.5" in the rear. Requires a SYE/CV shaft.
2. 2.5" suspension lift, with a 1" body lift, with 1" bumpstop extensions in front and 1.25-1.5" in the rear. The 1" BL usually accompanies a 1" Motor Mount Lift to offset some of the driveline angles.
Either way you go, figure on many of the following components: longer front brake lines, extended sway bar links front and rear, gears, brake and steering upgrades to accommodate larger tires, SYE, CV shaft, bumpstop extensions, new shocks, adjustable track bars, and a rear track bar bracket.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 16 Old 07-22-2011, 08:09 AM
gargyle
For exactly the same set up as you are looking for. I put a 2" Zone on my 2003 Sahara. I now have BFG 33x10.5 and it runs fine on the street. I also installed front and back adjustable track-bars.
gargyle is offline
post #10 of 16 Old 07-22-2011, 08:16 AM
Unlimited04
2" of lift alone isn't enough for 33s. the front adjustable track bar hits the diff cover or the tie-rod without copious amounts of bumpstop, and the rear track bar binds on the stock axle mount without a relocation bracket.
sorry
Useful Write-Ups:
Funny:
post #11 of 16 Old 07-22-2011, 08:23 AM
gargyle
That may be, but it works fine on my Jeep. I do not have any of those problems. However, it never goes off-road, it's pretty much a street only vehicle.
gargyle is offline
post #12 of 16 Old 07-22-2011, 09:04 AM
BobA
I'm happy with my RC 2.5 suspension and RC 1.25" BL combo.
Running 33x12.5's. It rides smoother than my factory suspension.
01 TJ Sahara
6cyl. 5spd, D30 Aussie/D44 LSD,4.56 gears, RC2.5" lift, RC1.25" body lift, 33's
77 DJ5
Soon to be streetrod
BobA is offline
post #13 of 16 Old 07-22-2011, 09:06 AM
jeepinmichguy_
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #14 of 16 Old 07-22-2011, 10:11 AM
mightydog78
this saddens me....
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #15 of 16 Old 07-22-2011, 10:23 AM
aj2006
I did a 4" zone, sye& ds. Adj UCA also. 33's run fine. It is added expense though the sye. Also if u run full size spare tire, u need rear bumper with tire carrier.
aj2006 is offline
4 inch , beginner , skyjacker , suspension lift
Manifold for beginners TheBeast TJ Wrangler Technical Forum 46 08-08-2011 06:45 PM
Beginners build for '11 JK 2DR Cajun53 JK Wrangler Technical Forum 3 03-01-2011 03:32 AM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
Beginners Shaft ekenfecker YJ Wrangler Technical Forum 4 12-06-2010 07:53 PM
Does this sound like an alright beginners set up? TOLjeep TJ Wrangler Technical Forum 17 08-28-2008 07:28 AM
