-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Beginners suspension lift (http://www.jeepforum.com/forum/f9/beginners-suspension-lift-1242622/)
Blakecognata6 07-21-2011 04:57 PM
i have a 2005 wrangler and i am looking for a suspension lift. i have found one that i am interested in for 483 dollars. its a skyjacker lift. (first one on this page>>http://4wheelonline.com/jeep/Skyjack...s.23917.261171
i don't know if i am making the right purchase. i am someone who will OCCASIONALLY take this on a small trail, no really extreme off roading. just looking for some opinions to see if this is a good beginners suspension lift.
Jerry Bransford 07-21-2011 07:22 PM
Bump to the top after a delay approving it.
Jay12 07-21-2011 07:31 PM
What size tire do you plan on running?
bstew417 07-21-2011 09:02 PM
For a beginners lift, I would stick with a 2-2.5" lift. Something like Old Man Emu will ride well on the street and not require transfer case drops, slip yoke eliminators, and other modifications along with it.
Blakecognata6 07-21-2011 11:04 PM
Well I was hoping to run 33's..
FXSTCHEWY 07-22-2011 04:33 AM
Zone 3" should work fine.
j_niko 07-22-2011 05:42 AM
With the proper backspacing of the rims, you can run 33s with a 2.5" lift.
M wife's 2000 has a 4inch Skyjacker (PO installed) and it rides extremely rough and likes to wander a bit.
I it was me, I would consider Rough Country's 2.5 with the new n2.0 shocks or Zone's 3".
I will be doing one of those two in the very near future on my 97.
Unlimited04 07-22-2011 07:01 AM
33's are fit in two common ways on TJ's:
1. 4" suspension lift, with 2" bumpstop extensions in front and 2-2.5" in the rear. Requires a SYE/CV shaft.
2. 2.5" suspension lift, with a 1" body lift, with 1" bumpstop extensions in front and 1.25-1.5" in the rear. The 1" BL usually accompanies a 1" Motor Mount Lift to offset some of the driveline angles.
Either way you go, figure on many of the following components: longer front brake lines, extended sway bar links front and rear, gears, brake and steering upgrades to accommodate larger tires, SYE, CV shaft, bumpstop extensions, new shocks, adjustable track bars, and a rear track bar bracket.
gargyle 07-22-2011 07:09 AM
For exactly the same set up as you are looking for. I put a 2" Zone on my 2003 Sahara. I now have BFG 33x10.5 and it runs fine on the street. I also installed front and back adjustable track-bars.
Unlimited04 07-22-2011 07:16 AM
2" of lift alone isn't enough for 33s. the front adjustable track bar hits the diff cover or the tie-rod without copious amounts of bumpstop, and the rear track bar binds on the stock axle mount without a relocation bracket.
sorry :thumbdown:
gargyle 07-22-2011 07:23 AM
That may be, but it works fine on my Jeep. I do not have any of those problems. However, it never goes off-road, it's pretty much a street only vehicle.
BobA 07-22-2011 08:04 AM
I'm happy with my RC 2.5 suspension and RC 1.25" BL combo.
Running 33x12.5's. It rides smoother than my factory suspension.
jeepinmichguy_ 07-22-2011 08:06 AM
:teehee:
mightydog78 07-22-2011 09:11 AM
this saddens me....
aj2006 07-22-2011 09:23 AM
I did a 4" zone, sye& ds. Adj UCA also. 33's run fine. It is added expense though the sye. Also if u run full size spare tire, u need rear bumper with tire carrier.
The time now is 06:17 AM.
