Bedliner in Tub - JeepForum.com
post #1 of 17 Old 05-13-2006, 03:12 PM Thread Starter
dbryan23
Bedliner in Tub
In the next few weeks I plan to remove the carpet from my '03 Sahara and coat the tub with some sort of roll-on bedliner. Herculiner sells a kit with a gallon of coating, brush, rollers, etc. for $100. Durabak is $80/gallon. Then there are various other brands. Does anyone have any advice on the brand or application tips?
dbryan23 is offline
post #2 of 17 Old 05-13-2006, 04:12 PM
4lo2.5
i used herculiner. loved it. dont let it get on your skin lol. make sur eto mask really well the areas you dont want covered. good luck its alot of fun
4lo2.5 is offline
post #3 of 17 Old 05-13-2006, 06:58 PM
rusty26
herculiner when dirty apply water
rusty26 is offline
post #4 of 17 Old 05-13-2006, 07:31 PM
keoki04
keoki04's Avatar
Herculiner has my vote!! Below is a link to a post I started when I did mine! Pics included if you're interested! Good luck!!!
http://www.jeepforum.com/forum/f9/herculined-tub-132564/
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
Clicky
Clicky
keoki04 is offline
post #5 of 17 Old 05-13-2006, 07:54 PM
lsufanjeeper
lsufanjeeper's Avatar
herc it you will love it
'98 Black TJ Sahara Soft Top
Member Of The "Playground" Jeep Club #03
Rubicon Express 3.5
BFG AT'S 33x1250x15'S
Got A 25,000 Tow Strap And Some Chains
Fabricated Shovel Mount On Inside TailGate
Midland Cb With 3' Firestick Channel 21
Some Cool Cosmetic Mods
Brush Guard
JKS Quick Disco's
Hood Mounted Highlift On The Way
Teraflex Steering Skid Plate
Hurculined
Hot Chick Riding Shotgun
Winch
GEAUX LSU TIGERS
.__0_0_0_0
[l_,[____],
l---L -OlllllllO-
()_) ()_)---)_)
lsufanjeeper is offline
post #6 of 17 Old 05-13-2006, 07:56 PM
Dogman
Dogman's Avatar
By the way, Herculiner and Durabak are made by the same company and are the same thing.
John 3:17
Dogman is offline
post #7 of 17 Old 05-13-2006, 09:18 PM
beemer-biker
My spare tire cover has the same thought line as your forum handle!
beemer-biker is offline
post #8 of 17 Old 05-13-2006, 09:22 PM
minileprechaun
then why do they have different names and durabak is cheaper?
are they completely the same .. or are there minor differences?
minileprechaun is offline
post #9 of 17 Old 05-13-2006, 09:24 PM
yellajeep04
yellajeep04's Avatar
I bought my Herculiner kit yesterday at Pep Boys for $59 after the $20 mail in rebate. Now to get a couple of free days to do it.
Mud is for fun, rocks are for throwing.
yellajeep04 is offline
post #10 of 17 Old 05-13-2006, 10:50 PM
CNY
Caught ridin' dirty
Please back this statement up with more details.
CNY is offline
post #11 of 17 Old 05-13-2006, 10:57 PM
CNY
Caught ridin' dirty
http://www.durabakcompany.com/productinfo.htm
Weight per gallon, pounds 10
Viscosity, Kreb units 67-72
Percent solids by weight R
Application temperature range 32oF-95F
Application thickness, 2 coats dry 29-39mils
Flexibility total flexibility
Resilience resilient in dry state
Abrasion resistance 30.5
Tabor wheel, 1000 gr load, 1000 cycles
Fire resistance
Flame spread ASTM E-162: 01
Smoke generation ASTM E-662: 06
Salt water resistance 100%
Freeze-thaw resistance -60oF to +254oF
Pot life 3 Hours
Shelf life min. 1 year
Flash time 1-1/2 to 3 hours
Walk time 6 to 12 hours
Time between coats + 1 hour
Full circle + 4 days
VOC 2.9 lbs/gal
DOT Hazmat Info coating, 3 UN1263, PG III
CNY is offline
post #12 of 17 Old 05-13-2006, 10:57 PM
CNY
Caught ridin' dirty
http://www.herculiner.com/images/herc_spec.pdf
• Weight per gallon, pounds 8.6
• Viscosity, Kreb units 67-72
• Percent, solids by weight 72%
• Application temperature range 32°F - 95°F
• Application thickness, 2 coats dry 29-39 mils
• Flexibility Total flexibility
• Resilience Resilient in dry state
• Abrasion resistance
Tabor wheel, 1000 gm load, 1000 cycles 30.5
• Fire resistance
• Salt water resistance 100%
• Freeze-thaw resistance -60°F to +254°F
• Pot life 3 hours
• Shelf life minimum 1 year
• Flash time 1-1/2 – 3 hours
• Walk time 6 to 12 hours
• Time between coats ± 1 hour
• Full cure ± 4 days
• VOC 2.7 lbs. / gal.
• DOT Hazmat info Paint, 3 UN 1263 PG III
CNY is offline
post #13 of 17 Old 05-13-2006, 11:00 PM
CNY
Caught ridin' dirty
Well, aside from the weights, the specs are identical. Looks like maybe the Herc is thinned more than the Durabak.
Anyone else have more info on this?
CNY is offline
post #14 of 17 Old 05-13-2006, 11:05 PM
minileprechaun
since herc is thinned more ... does that make it weaker and not as durable?
so would durabak be the better choice for do-it-yourself bed liner?
post #15 of 17 Old 05-14-2006, 09:04 AM
yellj
Here's another option, can't post pics here.
http://www.jeepsunlimited.com/forums...d.php?t=733926
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
bedliner lonestar_yj YJ Wrangler Technical Forum 1 01-15-2009 03:14 PM
DIY bedliner hollywood081470 TJ Wrangler Technical Forum 0 05-19-2008 06:52 AM
Bedliner Help Please, 02 Tj jooosooo TJ Wrangler Technical Forum 40 05-12-2008 09:23 PM
tub bedliner ?? MonsterMudder2 YJ Wrangler Technical Forum 2 03-12-2007 04:56 PM
Red or Tan Bedliner afguy TJ Wrangler Technical Forum 5 10-03-2005 08:12 AM
