#31 | |
but will that last
IS THAT GOING TO LAST THO those are pix of it just completed
#32 |
I need to know if they make a drain plug kit, as well as a stainless steel bolt kit, or am i gonna have to go size those all up myself at the marine shop ?
#33 |
#34 |
WHY DO MY images appear as links in anycase can you guys view the links posted ?!
#35 | |
We can see your links, though. ![]()
[QUOTE=Jeepinoldman]...he does a huge power barf right into the dash...[/QUOTE] |
#36 |
Well anyway I'm going down to the shop to get some serious sanding/prep work done and im gonna take pix, I mean I'm gonna put in like 20 hours of prep. I got all sorts of wire wheels, dremel's, I hate Torx so im swapping those out of my roll cage with some stainless Hex bolts.... Has anyone swapped out the torx for hex ?!
#37 |
You get what you pay for
that's a good idea to use stainless steel, as well as removing the torx. just be prepared for a battle and be careful not to strip the torx, as some of them are torqued down quite a bit (tailgate post piece for example).
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville “Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain † Christian Jeep Club † Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38 |
#38 |
Well The surface rust and intiation of rot was such a *****, I have pictures I'll but up later. Weather it was a wire brush bit for a drill or a wire wheel or a palm sander or a dremel its been a biotch... Today the front seat is coming out and center console.... and its getting all sanded up tonight. Then I'm laying down the Herculiner that should be coming today.
#39 |
Yep .. 2 years later it still looks the same
It's all in the prep .. and let it harden fully before reassembly.
---------------------- Formally 88Jeepster ---------------------- Who's in front ? Ridin' topless again .. sweet !! |
#40 |
![]() So I got those out with a dremel grinding wheel and course wirewheel bit for a screw gun |
#41 |
Oh and I got the stainless steel (sp?) hex bolts
So Its all in the prep i hope im doing okay because i had some rust starting to turn into what I believe to be the intial stages of it rotting... ![]() So with a whole array of tools i've gotten it to here... ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
