TO Bearing Replaced - Grinding - JeepForum.com
post #1 of 2 Old 06-24-2012, 02:02 AM Thread Starter
tghansen
Hi all. I searched for a while to find a solution, but nothing answers my questions, so here goes.
My TO Bearing was clearly toast (based on the noise it was making when the clutch was depressed), and I decided to do the job myself. All proceeded well (with the exception of the pilot bearing removal... finally decided that even though one came in the kit I bought, the one that was installed is in good enough shape to leave), and the jeep is now back together. Here's the problem:
On the first test drive after the job, there is some obvious play in the clutch, and if I feather the clutch, there is a point where something feels (via the foot pedal) like it's clunking around or grinding. These were the instructions I followed:
http://www.4x4xplor.com/clutch.html
and they seemed like good ones. What am I missing? [Please, oh please tell me that I didn't forget something inside the bell casing!!!] Any ideas what would cause this noise/feeling? It's not normal.
Thanks!
tghansen is offline
post #2 of 2 Old 06-24-2012, 02:19 PM Thread Starter
tghansen
From this page : http://www.jeepforum.com/forum/f9/cl...inding-759768/ It seems that when my T/O bearing blew, it took out the sleave also. I didn't realize it because there was nothing resembling a broken sleave left inside the case. I do remember that when I replaced the TO bearing I was surprised to see that it slipped onto the shaft with a lot of clearance. I'm pretty sure that's my issue.
I'll post back when I'm positive.
tghansen is offline
clutch
Steering slop due to shaft bearing, can bearing only be replaced? Lemmiwinks TJ Wrangler Technical Forum 4 05-01-2011 07:53 PM
Anybody ever had to have the Throwout Bearing Replaced in a TJ? gotjeep TJ Wrangler Technical Forum 4 05-16-2010 04:36 PM
Rear brakes. Grinding. Replaced but with ?'s DezDiggler TJ Wrangler Technical Forum 7 12-03-2008 05:03 PM
Replaced hubs, still got a grinding noise... BringThaPain TJ Wrangler Technical Forum 5 09-22-2008 08:00 AM
Replaced clutch - gears are still grinding Rocky529 YJ Wrangler Technical Forum 10 09-16-2008 02:44 PM
