bds shock shifters - JeepForum.com
post #1 of 5 Old 08-15-2005, 08:20 AM Thread Starter
TSWRA
bds shock shifters
has anyone installed the BDS shock shifters or Shock relocaters ? If so .. do you have any pics ?
99 TJ Auto Sport 4.5 BDS Warn 9.5ti ARB's 33" Trxus (Kilby,Currie,Crane and Skid Row skid plates)
TSWRA is offline
post #2 of 5 Old 08-15-2005, 08:33 AM
Muddeprived
Muddeprived's Avatar
I would like to see as well. I noticed a nice dent in my new ome rear shocks from the coil plate. Looks like I have a reason to spend more moola
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #3 of 5 Old 08-15-2005, 08:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Shock relocation brackets often cause torn mounts by giving rocks even more leverage against where the OE mount is welded to the axle. Have you considered just flipping the rear shock upside-down which gives the shock body more clearance away from the lower spring perch? Most shocks work fine either direction, though it should be verified with your exact shock model.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #4 of 5 Old 08-15-2005, 10:47 AM
Muddeprived
Unfortunatly for me, I cannot flip them because OME uses steel rod covers that are slightly larger in diameter than the shock body so that won't work.
post #5 of 5 Old 08-15-2005, 02:10 PM Thread Starter
TSWRA
The BDS shock cannot be flipped either. Its not bad at all and I think I may just grind the spring perch a bit.
TSWRA is offline
Nth Degree/AEV Rear shock shifters sduncan TJ Wrangler Technical Forum 5 08-30-2009 10:41 PM
anyone use Nth Degree Mobility Shock Shifters Rafikie TJ Wrangler Technical Forum 3 07-18-2008 04:37 PM
Shock Shifters and 8.8 TSWRA TJ Wrangler Technical Forum 6 10-18-2005 10:43 PM
Doh!! Looks like it's time for some Nth° Shock Shifters wayoflife TJ Wrangler Technical Forum 6 02-14-2005 12:45 PM
