-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   bds shock shifters (http://www.jeepforum.com/forum/f9/bds-shock-shifters-185079/)
TSWRA 08-15-2005 08:20 AM
bds shock shifters
has anyone installed the BDS shock shifters or Shock relocaters ? If so .. do you have any pics ?
Muddeprived 08-15-2005 08:33 AM
I would like to see as well. I noticed a nice dent in my new ome rear shocks from the coil plate. Looks like I have a reason to spend more moola :)
Jerry Bransford 08-15-2005 08:43 AM
Shock relocation brackets often cause torn mounts by giving rocks even more leverage against where the OE mount is welded to the axle. Have you considered just flipping the rear shock upside-down which gives the shock body more clearance away from the lower spring perch? Most shocks work fine either direction, though it should be verified with your exact shock model.
Muddeprived 08-15-2005 10:47 AM
Unfortunatly for me, I cannot flip them because OME uses steel rod covers that are slightly larger in diameter than the shock body so that won't work.
TSWRA 08-15-2005 02:10 PM
The BDS shock cannot be flipped either. Its not bad at all and I think I may just grind the spring perch a bit.
The time now is 11:10 AM.
