BDS lift question - JeepForum.com
post #1 of 12 Old 05-12-2013, 07:25 AM Thread Starter
ajmasoniv
BDS lift question
Hi Guys,
New to the Jeep world; just bought my 06 Rubi in the fall and I'm starting down the upgrade path. I have a question for the experts here. Found a guy selling a used BDS 4.5 short arm kit for a standard TJ. I see that BDS makes two different kits for the TJ, a standard one and one for the Rubicon. Can you put the standard version on the Rubi? The price is right, so if it fits, I would be pumped. Any help would be appreciated...
John
'06 TJ Rubi 3.5" Rock Krawler XFactor SA lift, 33" Mud Grapplers, Bilstein 5100s
ajmasoniv is offline
post #2 of 12 Old 05-12-2013, 07:34 AM
Ironhead
its just springs and shocks, shouldnt make a difference at all. the real question is, do you need a 4.5" lift and do you have all of the parts required to make it happy on-road. ie. rear adj control arms, cv driveshaft, adj track bars front and rear, and welding abilities?
Ironhead is offline
post #3 of 12 Old 05-12-2013, 07:57 AM Thread Starter
ajmasoniv
Thanks for the reply Ironhead. The control arms with the kit are adjustable. I would still need the adjustable track bars and CV driveshaft. Luckily, I have friends with welding skills. Every time I try, it looks like a blind kid went at it....
post #4 of 12 Old 05-12-2013, 08:03 AM
tyvanwie
If you're aware of the problems that will arise from a 4.5" lift, then I say go for it.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #5 of 12 Old 05-12-2013, 09:24 AM
achilless
You are getting a good price on it, so the $500 bucks saved can go towards driveshaft and other things you might. All I can see you needing is adjustable arms, driveshaft, and track bars. Mml would be a good idea too.
2002 TJ Sahara: 4" Zone/ 1.25" BDS body lift. 35" Km2's, Dana 44-LSD, Dana 30-Lokka Locker, JKS 1" motor mount lift, TheDirtWorx bumper/carrier, Smittybilt XRC 8000 Winch, D rings front + rear, Hi-lift
achilless is offline
post #6 of 12 Old 05-12-2013, 11:50 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Who said he saved $500 and why would he need a driveshaft.He said it has adjustable CAs.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #7 of 12 Old 05-12-2013, 12:28 PM
pariah24
Because setting the correct pinion angle doesn't mean it'll get rid of binding on the driveshaft. It's a combination of the two to fix these issues. Not to mention that 4.5" of lift on a stock length driveshaft is asking for issues at flex.
Granted, I'm a YJ guy just getting into TJs but what holds true for one should hold true for the other.
pariah24 is offline
post #8 of 12 Old 05-12-2013, 02:05 PM
tjsean0308
Let us know how that drop pitman arm works with that 3" lift. but I agree double cardigan driveshaft and upper control arms go together on a 4" or greater lift.
tjsean0308 is offline
post #9 of 12 Old 05-12-2013, 02:30 PM
Gary2
If you save 500 bucks , I would pick up a Currie Currectlync.That and Duroflex control arm bushings have been my best mod to date . You will need a rear DS , front and rear TBs a Good set of control arms most likely, BM brakes at a minimum for stopping what ever kind of rubber you plan on running that requires 4.5" of lift. If its automatic figure on modding the trans skid plate front driveshaft clearance
Gary2 is offline
post #10 of 12 Old 05-12-2013, 03:17 PM
pariah24
Pssht. I'm still trying to figure out how to go SOA on my new TJ.
pariah24 is offline
post #11 of 12 Old 05-12-2013, 03:19 PM
Ironhead
they come stock as a SOA
Ironhead is offline
post #12 of 12 Old 05-12-2013, 06:47 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Good point!...
Knuckelhead is offline
bds lift
