BDS 2" lift true yield... - Page 2 - JeepForum.com
post #16 of 25 Old 06-20-2010, 10:29 PM
2006_Sport
Originally Posted by SloLearner View Post
r all spacers pretty much created equal? i was wanting to throw in a .75" or 1" spacer up front too? and where did u get ur lift? locally or a good price on the internet out there?
Yeah, they're pretty much all the same.
Originally Posted by speed_phreak View Post
Thanks for your help 2006sport!
Yea, but do you have a 4 speed auto with a dana 44? That seems to be a deadly vibe combo in the research I have done here... But I do appreciate your help.
No problem man, glad I could help.
2006_Sport is offline
post #17 of 25 Old 06-20-2010, 11:17 PM
IslandTJ
FWIW, I run the 2" BDS lift and I am very satisfied with my lift's performance both on and off road .
Now Jeeping in Oregon
IslandTJ is offline
post #18 of 25 Old 06-24-2010, 11:12 AM
danielbuck
1946 CJ2
2" BDS went on mine today, it rides just like factory, and possibly takes big bumps even better! I don't know if I can do a direct comparison though, since tires went on at the same time. That might be part of the big-bumps difference I'm noticing, since there's more tire there. But it's surely no worse than stock ride quality. I don't know how to measure the true lift either, again since tires went on at the same time. I like it, good buy!
danielbuck is offline
post #19 of 25 Old 07-28-2010, 02:02 AM
Kiwi_TJ
2" BDS Flex!
Here is my Jeep with the 2" BDS Kit Installed on the ramp! I love the way it rides, great kit.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #20 of 25 Old 08-19-2010, 12:23 PM
Fargo
I had a bit different of an experience than everyone else here. I put the BDS springs on my Rubicon LJ and I only gained about 1.5" up front and 2" in the rear. Now I'm not sure if thats because I have a LJ or a Rubicon or if I just got a bad set. You can read my review here http://www.jeepforum.com/forum/f9/my...-info-1059480/
Since I got the BDS springs and Rancho shocks I can't comment on the BDS 'kit'. But my setup is a bit stiffer than stock. It worked great off road this past week when I was loaded down in Colorado, but sometimes, when I'm empty, I feel it is a bit stiff for my taste. But I can't tell you if that's because of the springs or the shocks.
I was in contact with BDS about the height gain, but I decided to just drop it and keep what I have since the stance is pretty decent. I tend to think that my Rubi was sitting higher than others to begin with. So I wouldn't worry too much about not getting enough lift. But be aware that it has happened.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #21 of 25 Old 08-19-2010, 02:59 PM
kgginslc
Originally Posted by Kiwi_TJ View Post
Other parts well worth getting that I got was a OME rear track bar relcoation bracket. It attaches to the body mount end and lowers the mount and moves it inboard a bit, it centred my rear axle perfectly.
I thought it attached to the axle - no? I haven't installed mine yet because I read that someone said it would hit the tub, and I'd rather live with an offcenter axle than damaged body.
kgginslc is offline
post #22 of 25 Old 08-19-2010, 11:25 PM
2006_Sport
the 2 inch bds flexes naice
post #23 of 25 Old 11-04-2010, 06:26 PM
jbg1980
With the 2" BDS lift is a transfercase drop required?
jbg1980 is offline
post #24 of 25 Old 11-04-2010, 06:59 PM
Kiwi_TJ
I have a 1997 TJ sport with the 4.0 Litre engine and the AX-15 manual 5 speed gearbox, Dana 44 rear axle, and needed to use a 1" transfer case drop, I used an OME one that a friend had taken off. I had terrible vibes prior to that.
You might get away with not having one if you use a LOPRO transfer case mount.
With the OME rear track bar bracket, it bolts on to the frame, well, the one we get on our side of the world does anyway.
Hope that helps
Kiwi_TJ is offline
post #25 of 25 Old 11-04-2010, 07:02 PM
jbg1980
Do you think using the LOPRO mount and the UCF no body lift skid would prevent me from having vibes? I thought there was converter interference with the LOPRO mount?
jbg1980 is offline
bds , lift kit , 2"
True 5" Fender Flare for TJ Steve N TJ Wrangler Technical Forum 4 12-01-2008 07:54 PM
Looking for springs that will yield 3.5" of lift +GRAVES+ TJ Wrangler Technical Forum 21 09-26-2008 03:02 AM
how much lift does the re3.5 really yield? alex71 TJ Wrangler Technical Forum 8 04-07-2006 08:58 PM
True or False about 2" lift OSCS Paul TJ Wrangler Technical Forum 8 03-22-2006 11:47 AM
True or false? On the "its a jeep thing, you wouldn't understand" saying... Jeep84CJ7 TJ Wrangler Technical Forum 28 12-28-2003 07:57 AM
