Is the battery going? - JeepForum.com
post #1 of 6 Old 07-03-2010, 04:46 PM Thread Starter
Camo Deere
Camo Deere's Avatar
When I try to start the Jeep with the clutch fully engaged and try to crank it, nothing happens(almost like a dead battery). But, if I crank the key and hold it fully turned then slowly press the clutch in, when it gets to a certain spot it will crank over.
I have never heard of this, is this just the battery going or is this another problem?
Camo Deere is offline
post #2 of 6 Old 07-03-2010, 04:52 PM
srwilson8074
Do you have a safety switch on the clutch linkage? You might have to clean it and put some dielectriuc grease on connection after you clean it. Hopefully this helps
srwilson8074 is offline
post #3 of 6 Old 07-03-2010, 04:55 PM
tj98
Check your owners manual, on my 98 there is a fuse you can put in to bypass the clutch safety switch "for off road use only". I've had the fuse in since I bought it a couple of years ago.
tj98 is offline
post #4 of 6 Old 07-03-2010, 07:20 PM
wushaw
Rockin jeep
wushaw's Avatar
Yea you got a bad clutch saftey switch, replace it, bypass it or do the fuse trick.
wushaw is offline
post #5 of 6 Old 07-04-2010, 06:12 AM
srwilson8074
I would really consider replacing unit, by passing this safety feature could bit you in the butt if you ever get into an accident. A buddy of mine did the same thing and got into a bender in the parking lot and insurance denied claim for altering safety features, Insurance companies suck
S.R. Wilson Sr
post #6 of 6 Old 07-04-2010, 08:32 AM Thread Starter
Camo Deere
Camo Deere's Avatar
I can see that happening if they found out. I'm going to look at what srwilson said and check it out and clean it, then replace if it need be
Thanks for the help everyone
battery , clutch safety switch
Smittybilt Dual Battery Tray & Battery Temp Sensor. 05jeeper TJ Wrangler Technical Forum 6 07-23-2010 08:32 AM
YJ losing battery juice while running-battery/alternator good Dannyboy6292 YJ Wrangler Technical Forum 20 01-13-2010 11:54 AM
Dual battery placement.. will (blank) hurt a battery? jeepgunner12 TJ Wrangler Technical Forum 5 01-04-2010 02:09 PM
Anyone use a battery isolator and dual battery setup? BNovak TJ Wrangler Technical Forum 5 12-07-2009 06:16 PM
battery dead ....argh... dual battery setup???? asjeep TJ Wrangler Technical Forum 21 07-20-2009 05:46 AM
