Battery is fine but engine will not crank. had to roll it back in forth then try... - JeepForum.com
post #1 of 13 Old 11-19-2009, 11:53 AM Thread Starter
Mitchin
well it only turned over after i rolled her back and forth. the battery seems fine. its been actin up for a while but then last night it just didnt start at all!?
NIGHT CREW #16
Yellow Jeep Club #67
My Build Thread-
Mitchin is offline
post #2 of 13 Old 11-19-2009, 11:59 AM
NotURMailman
NotURMailman's Avatar
Starter?
Check for power to the starter with the key in the start position. If you have power, then I would say you need a new starter.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 13 Old 11-19-2009, 11:59 AM
mdm
Farm Wheeler
Are you rocking it in gear?
Sounds like you have a starter and/or flywheel ring gear problem.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 13 Old 11-19-2009, 12:06 PM Thread Starter
Mitchin
well then i just went out to start it and it worked wtf!? no wheni rocked it it was out of gear. yeah i had full power it just would not start last night.
NIGHT CREW #16
My Build Thread-
Mitchin is offline
post #5 of 13 Old 11-19-2009, 12:08 PM
NotURMailman
How do you know you had "full power"? You need to check for power at the starter. Otherwise it could be a lot of other things causing a lack of either supply voltage or start signal to the starter. You need to check that the starter is getting proper supply and signal with the key in the start position.
post #6 of 13 Old 11-19-2009, 12:11 PM
Edstu234
Sounds like a starter problem or cable that leads to the starter. There are contact points on the start just like on the battery. Check those and tap (Not Smack) the side of the starter with a hammer. The starter might have binded up.
Edstu234 is offline
post #7 of 13 Old 11-19-2009, 12:31 PM
Kinless
There is a common problem with mopar starters in the washer / fork contact by the starter solenoid ( sorry my spelling and technical description suck but I know what I am trying to describe LOL ). Replace this washer when you find you have to click the ignition a few times to get starter to engage as opposed to buying a new starter.
Kinless is offline
post #8 of 13 Old 11-19-2009, 12:56 PM
MUDDYSAHARA
if its your starter, it'll happen again, you just have to wait and see. or it magically fixed itself like they are prone to do.
Yeah right!!!! Unless you wanna work 40 hours a week!!! Geez!!!
MUDDYSAHARA is offline
post #9 of 13 Old 11-19-2009, 01:00 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Before getting too deep here, start off with the simplest of basics and go from there... you need to first remove both battery cables and clean them and the battery posts with a wire brush. IF the battery is good like you claim it is, the usual cause for this problem is nothing more than a bad battery connection.
Don't just look at the battery connectors and pronounce them ok either, you really need to remove and clean them with a wire brush and reconnect them solidly before suspecting anything more complex or more expensive.
Jerry Bransford is offline
post #10 of 13 Old 11-19-2009, 02:14 PM
Ross
My TJ and esp the Grand I had were real picky about this. Clean connections and make sure they are tight.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #11 of 13 Old 11-19-2009, 02:17 PM
mrcarcrazy
and visually inspect the cables themselves. if the insulation looks old/rotten, or you can see rusted wires replace the cables.
I'm with Jerry on this one, the intermittentness of the problem screams connection issue somewhere.
mrcarcrazy is offline
post #12 of 13 Old 11-19-2009, 07:42 PM Thread Starter
Mitchin
ill check tomorrow but the battery was replaced at jeep a month ago cause the old one had a dead cell.
NIGHT CREW #16
My Build Thread-
Mitchin is offline
post #13 of 13 Old 11-20-2009, 09:49 AM
AER2007
http://www.jeepforum.com/forum/f9/st...g-read-853439/
You're starting to be beyond pedantic and that's my job, quit trying to take it from me.
Originally Posted by ageorgakis View Post
No, I wasn't being comical. I'm being perfectly honest. I don't have any dyno tests. But you can FEEL the difference!
AER2007 is offline
slow to crank over.. battery or starter? paroxysym TJ Wrangler Technical Forum 22 01-12-2016 06:20 PM
99 TJ Sport - Crank, No Start, Ran Fine before. redroof TJ Wrangler Technical Forum 3 10-14-2009 08:04 AM
Loss of power, back firing. Now everything is fine... Red_91_YJ YJ Wrangler Technical Forum 0 05-19-2009 09:55 AM
Jeep Won't Crank After New Battery FlyParrotHead TJ Wrangler Technical Forum 14 01-12-2009 01:57 PM
Help, No Crank Battery Good. stevensinger TJ Wrangler Technical Forum 11 02-11-2008 06:14 PM
