basic maintenance question - JeepForum.com
post #1 of 6 Old 08-26-2005, 08:58 AM Thread Starter
base shakers
so i just did my first oil change on my new jeep, and i see in the manual that you should lube the suspension. what does that entail? i know their are grease fittings etc, what mates to them? what type of lube should i use?
'05 LJ, ~4" lift, 35X12.5 Toyos, 16" beadlocks, HPD44, HPD60, 4-speed Atlas, 4.6L stroker
base shakers is offline
post #2 of 6 Old 08-26-2005, 09:20 AM
moosepks
Go to your local autozone and buy a greasegun and some grease. You will probably need to buy a flexible hose also. Just press the end of the gun onto the zirk fittings until it kinda locks into place. Then just pump them full of grease. You will see the rubber donuts start to bulge out.
2005 Black Rubicon Unlimited
3.5" RE Lift
33x12.5x15 TrXus MT's
Jackalope rear tire carrier
moosepks is offline
post #3 of 6 Old 08-26-2005, 09:21 AM
scottcha
scottcha's Avatar
Get a grease gun and grease at your local auto parts store. Don't bother with the mini grease gun, get the full sized one. There are six grease fittings on the front of your jeep, you should grease them every time you change the oil. Don't over fill the grease fittings otherwise you'll burst the rubber grease housing.
'99 TJ
White Jeep Club member #178
Colorado Jeepers Club member #7
scottcha is offline
post #4 of 6 Old 08-26-2005, 09:21 AM
otisdog
2008 WK
Grease gun with a tube of chassis grease. The grease zerks are all on the front - top ball joints , tie-rod ends etc. Look under there and you will see them. There's seven I think. Pretty easy job but messy.
jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 6 Old 08-26-2005, 09:29 AM Thread Starter
base shakers
thanks guys!
post #6 of 6 Old 08-26-2005, 09:46 AM
Jeepin' Rock Cl
Jeepin' Rock Cl is offline
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic Maintenance - Engine Oil Change Mean Max YJ Wrangler Technical Forum 48 01-21-2015 01:18 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
Basic day-to-day maintenance question (newbie) drunkinjacket TJ Wrangler Technical Forum 12 07-31-2004 09:16 PM
