Basic day-to-day maintenance question (newbie) - JeepForum.com
post #1 of 13 Old 07-29-2004, 06:05 PM Thread Starter
drunkinjacket
Just got to the point I'm able to do much of the monthly maintenance on my 2001 sport myself, but am new to it. Been doing the oil change, filter change for awhile, but there are other things I'd like to start doing. If anyone has some step by steps, or knows a site with some pictures, I'd like to know
How to drain and fill the front and rear axles (how often should this be done, what tools should you use, what should you fill it back up with?)
How, and with what do you lubricate steering and suspension ball joints
How, and with what do you lubricate the tie rods.
I know most of these may sound dumb, but my last car was a Honda, and wasn't worth working on. My Jeep I really want to take good care of, and want to know how much I can feasibly do in my garage, and how to do it.
Thanks
drunkinjacket is offline
post #2 of 13 Old 07-29-2004, 06:41 PM
AjRagno
There isn't much to it really. Buy a set of jack stands (the taller the better), a floor jack and a grease gun. Along with the grease gun, you'll need a flexable hose and a head with a 90 degree angle to reach most of the fittings easily.
I use Mobile 1 motor oil and change it every 5,000 miles. At the same time, I also rotate the tires and lubricate the steering links.
For other maintanence write-ups, check:
www.stu-offroad.com
www.4x4xplor.com
AjRagno is offline
post #3 of 13 Old 07-30-2004, 03:00 PM Thread Starter
drunkinjacket
thanks, and one more thing
when you rotate, do you balance as well? Is there anything you can buy that will help you with that. Not sure it's really necessary, as speed is not what the wrangler is built for, but would like to keep the wear on the tires as even as possible.
above and beyond the oil change, filter changes and greasing, is there any other "recommended" weekly, or monthly maintenance? Just curious, and is the how to covered on the sites you listed.
Thanks,
post #4 of 13 Old 07-30-2004, 03:35 PM
htownjeep
What's that noise?
htownjeep's Avatar
Thanks,
Stu's site is my personal favorite. He has not only how-to's, he also has tons of digital camera pics to go along with it. I've even e-mailed him a few times and he's yet to be stumped by me on anything!
Drink upstream from the herd.
htownjeep is offline
post #5 of 13 Old 07-30-2004, 04:10 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Get yourself a FSM (Factory Service Manual). And remember - don't pump too much grease thru those fittings or you'll pop the seals.
04JeepTJ is offline
post #6 of 13 Old 07-30-2004, 08:29 PM Thread Starter
drunkinjacket
don't want to pop anything....
so, basically just pump enough through that it begins to seep out, or would one good squeeze do it? Would it only pop if you continue to pump greese in well after it's had a sufficient amount?
post #7 of 13 Old 07-30-2004, 08:32 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
don't let it seep out. pump until it's firm. you'll need to use your hand and pinch the seal to tell when to stop.
actually it probably doesn't matter if it starts to seep out because you've got a ton of lube in there anyway and it's probably alright if you check the seals everytime you change your oil or after you go thru water off-roading.
04JeepTJ is offline
post #8 of 13 Old 07-31-2004, 07:09 AM Thread Starter
drunkinjacket
Question: Important
the "fill bolt" that, on the front, is what appears to be a drainage bolt, right. On the rear axle its a rubber plug. My question is, what is the hose running up to the engine block. comes up from the front axle, and runs up (as your facing the engine with knees at the front bumper) to the right of the radiator? Just curious. Is this a fill point, too.
post #9 of 13 Old 07-31-2004, 05:10 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
That hose is the vent hose for your front axle. Your tranny and rear axle prolly also have one.
The front you have is a dana 30 and it has a square 3/8" bolt. You should remove the diff cover slowly to drain, then remove the cover, scrape the RTV off, clean everything, put RTV on, put the cover back on with the bolt out and fill. There is a few writeups - check out the FAQ's. The rear diff is the same except if you have trak-lok you need to add about 4 oz of "friction modifier". Don't forget to do the tranny + transfer case they're really easy. The transfer case has 2 bolts - one to drain, one to fill. Make sure you can get both bolts loose before draining so you don't get yourself into a pickle if you can only open the drain bolt....
04JeepTJ is offline
post #10 of 13 Old 07-31-2004, 05:14 PM
War Eagle
BRAAAAIIIIIIIIIIIIIINS!!!
War Eagle's Avatar
Where do you get those?
Originally Posted by Keith
JF without War Eagle? That's like a beach without broken glass littered about. I shudder at the thought.
Originally Posted by Thexonexkid View Post
I was under the assumption that you were Keith?
War Eagle is offline
post #11 of 13 Old 07-31-2004, 05:16 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
FSM, pump, grease, fittings, or seals?
04JeepTJ is offline
post #12 of 13 Old 07-31-2004, 05:21 PM
War Eagle
War Eagle's Avatar
FSM, please
post #13 of 13 Old 07-31-2004, 09:16 PM
htownjeep
What's that noise?
htownjeep's Avatar
Originally Posted by praxis
FSM, please
Ebay's a good bet....always one there. Sure there's other places but I see plenty of them there.
Basic Maintenance - AX-15 Oil Change Mean Max YJ Wrangler Technical Forum 207 04-23-2016 05:25 PM
Basic diff lube maintenance Mean Max YJ Wrangler Technical Forum 85 01-20-2016 12:46 PM
Basic maintenance write-ups? Belfast TJ Wrangler Technical Forum 7 09-28-2009 09:25 AM
Couple Basic Maintenance Q's Black Hills TJ TJ Wrangler Technical Forum 4 06-30-2007 02:16 PM
basic maintenance question base shakers TJ Wrangler Technical Forum 5 08-26-2005 09:46 AM
