Barnes 4WD TJ flat skid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Barnes 4WD TJ flat skid
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 04-14-2013, 11:18 PM   #1
creepn
Just looking for some info on this flat skid http://www.barnes4wd.com/Jeep-TJ-Fla...ate_p_220.html
Is anyone running this skid with the UCF lo-pro mount? I like the completely flat design which would let the t-case sit a bit lower for better clearance and driveline angles. Might need to weld in some support to stiffen it once everything is lined up but that's easy enough. The price is hard to beat. Haven't seen much talk about this skid, just UCF and Savvy. What's the JF thoughts on it?
Thanks
creepn is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 11:28 PM   #2
rbkelley89
ive got this skid the 0" drop. hardest part was getting the holes drilled for the t case mount. i have an 01 2.5 auto so no lo pro for me but if i could use it i would strongly urge that you do. right now mine is mounted directly to the stock bulky t case mount. Get it and fab it up save a few hundred bucks and have a totally flat belly! One thing i wish they did was countersink the mounting holes for a flat mount!
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 06:46 AM   #3
robhurlburt
should be easy enough to take care of yourself, no?
robhurlburt is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 07:36 AM   #4
Imped
Imped's Avatar
You can't countersink the mounting holes due to the manufacturing variance.....some would line up, many would not. If you want countersunk holes, you have to start with a fresh, bare skid and map the hole centers yourself.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 07:58 AM   #5
J03_TJ
J03_TJ's Avatar
Guess I lucked out, the Nth skids came with countersunk holes and line up perfectly (well close to that).
J03_TJ is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 08:04 AM   #6
Imped
Imped's Avatar
Nth probably allowed some wiggle room with larger holes and a wider countersink. That's one way to do it.
OlllllllO
Float Test Build
IndyORV
Unread 04-15-2013, 08:07 AM   #7
J03_TJ
J03_TJ's Avatar
Yep, and they pulled it off across 4 bends since the skid isn't flat.
Unread 04-15-2013, 10:44 AM   #8
rbkelley89
And oh yeah if you get the barnes save yourself the trouble and cut the bent lips where the front ds goes and the exhausts on both ends. A ds tunnel will probably need to be cut into it unless you have a hp or are below 4" lift
Unread 04-15-2013, 02:10 PM   #9
creepn
That's what I'm looking at... got any pics you could post up? I've got an HP30 and only 3" lift so it sounds like it wouldn't take too much tweakin to make it work. Looks like I'll be going this way in the next month or so.
Thanks
Unread 04-15-2013, 03:59 PM   #10
rbkelley89
yup here u r
Unread 04-15-2013, 04:02 PM   #11
rbkelley89
didnt mean to upload the last one.
Unread 04-15-2013, 04:20 PM   #12
creepn
Awesome... that's exactly what I need! Thanks for the pics and info.
Unread 06-18-2013, 06:12 AM   #13
AdamLC
Is it necessary to run a BL to get the 0 drop skid? I was thinking of flushing the trans mount bolts by taking some 1" square tubing and cutting in half or so and welding it on top of the plate and that's where the trans mount will sit ontop of. And of coarse drill a few holes in the skid to thread the nuts through but I wouldnt have the nuts and studs protruding from the bottom of the skid.
AdamLC is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 10:51 AM   #14
NotURMailman
Sounds like you're talking about raising the trans mount off of the top surface of the skid? If so, I don't think that's going to work.
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote Quick reply to this message
Unread 06-18-2013, 10:57 AM   #15
Imped
Imped's Avatar
You need a certain amount of space that isn't there from the factory. How you get it is up to you.
OlllllllO
Float Test Build
IndyORV
