Bar Pin Eliminators - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Bar Pin Eliminators
XJ guys, clock your transfer case!D.i.y. Ford 8.8 tj,xj,yjTrek Armor Seat Covers now at JeepHut
Unread 08-17-2011, 08:04 PM   #16
tangofox007
Originally Posted by esad_b View Post
The JKS bar pins.. they use hex bolts to mount wouldn't that be a PITA to install?
Front JKS BPE's mount with hex head bolts. Rear version uses socket head cap screws. The socket head cap screws have a tendency to strip out (the internal hex) when approaching specified torque.
tangofox007 is offline   Reply With Quote
Unread 08-17-2011, 08:11 PM   #17
esad_b
Ya so that's a real bad deal especially considering if you have to swap shocks you need to take those bolts out due to design to replace shock.
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
--- 2.5L | 5SPD | 31" Goodyear Authority A/T | 15" Alloy Ecco Wheels | Rubicon Rocker Guards ---
My Progress Page
esad_b is online now   Reply With Quote
Unread 08-17-2011, 08:48 PM   #18
djfuzzy
Having BPEs is a pain the ***. Remove your shocks, lift the tub off the frame, break the tac welded nut off, tac a new one on, put tub back down, replace the bar pins themselves, put shocks back on, enjoy life.
I put JKS BPEs on my shocks that came with my lift and uninstalled them with haste when I got Bilsteins. I don't know if it's just Bilsteins or all quality shocks, but they come with much higher quality bar pins than the factory shocks do.
Sent from outer space
USMC 2006-Present
Sold: 2000 TJ - D44/D30 with 4.88s, Advance Adapters SYE, Tom Woods CV, Vanco Big Brake kit, 35x12.50 BFG KM2s, ProComp Series 51s, Rough Country 4" Series II, Bilstein 5100 Shocks, Currie HD Steering, Rokmen Adjustable Control Arms, ProComp Adjustable Trackbar, Currie Anti-Rock, MetalCloak Front Bumper and Stinger, Warn rear bumper/tire carrier
djfuzzy is offline   Reply With Quote
Unread 08-17-2011, 10:31 PM   #19
rangojeep
I broke a rear upper shock bolt (while on the highway) and found someone had tried to repair it previously. The shop welded a Rough Country style BPE on that side then told me that my OME Nitrocharger shock would not work with it. Is this true? I am running it with another brand shock - I hope temporarily.
rangojeep is offline   Reply With Quote
Unread 08-18-2011, 07:42 AM   #20
Erik T.
I'd like to know about OME's not working with BPE's, cause thats what I was planning on going with next.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline   Reply With Quote
Unread 08-18-2011, 08:00 AM   #21
djfuzzy
I'm pretty sure that the JKS bar pins explicitly state that they do not work with OME shocks.
EDIT: check the link towards the bottom where it shows part numbers for Jeep models.
http://store.jksmfg.com/merchant2/me...ory_Code=Shock
USMC 2006-Present
Unread 08-18-2011, 09:15 AM   #22
esad_b
Yes they do state that. Now what BPE are the best?
Are the RC ones okay even tho they rotate the top eye by 90"?
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 08-18-2011, 12:28 PM   #23
djfuzzy
I didn't have a problem with the JKS ones, besides when I changed my shocks for Bilsteins and went back to bar pins. I don't think there is a 'best' because they all seem to slightly limit travel of your shocks.
USMC 2006-Present
Unread 08-18-2011, 12:43 PM   #24
JWebber
Just the fronts right?
JWebber is offline   Reply With Quote
Unread 08-18-2011, 12:47 PM   #25
esad_b
No the rears.
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 08-18-2011, 12:57 PM   #26
JWebber
Really am I missing something?
Unread 08-18-2011, 01:02 PM   #27
esad_b
Okay your second picture. Is that your actual picture of the Rough Country ones?
Because they rotate the top bushing by 90", look closely at this pic.
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 08-18-2011, 01:06 PM   #28
hustler905
I see what you mean, but on an otherwise stock suspension the orientation of the shock bushing relative to the way it wants to pivot with flex really won't make much difference.
hustler905 is offline   Reply With Quote
Unread 08-18-2011, 01:51 PM   #29
esad_b
Ive been reading that it causes binding..
****! Day went by and I didn't get a set of any of these.. damn it.. the place here is telling me 2 weeks before they can get them in..
hustler905: Any places up your way that will ship down here to atlantic canada?
(O|||||||O)
l_l*-----*l_l
1997 JEEP TJ
My Progress Page
Unread 08-18-2011, 02:08 PM   #30
JWebber
Yes Those pics came from their website and install photos. I think the one shown are the Teraflex ones.. that someone else posted.
http://www.roughcountry.com/jeep_xtr...liminator.html
