Bank 2, Sensor 2 oxygen sensor... - JeepForum.com
post #1 of 3 Old 09-19-2009, 01:22 PM Thread Starter
Alexia
Alexia's Avatar
Any ideas as to why this sensor is such an odd ball? This is the bank two, sensor two on the fifty states 2000-2006 model Jeeps. It appears to be a factory sensor, but there is no shield around the tip. The white part of the tip is where the carbon build up deteriorated and took part of the ceramic with it.
The replacement sensor was much more massive, a different design than the rest, and had the appropriate shield over the ceramic.
The other three sensors I removed had their appropriate shields around them.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #2 of 3 Old 09-19-2009, 01:26 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I wonder and assume that if it fell off?
GOLENJEEPTJ is offline
post #3 of 3 Old 09-19-2009, 01:29 PM Thread Starter
Alexia
Alexia's Avatar
I looked at it a few times and while I can not seem to identify where a shield may have been attached, I some times get this random rattling noise from the exhaust.
Alexia is offline
BANK 1 SENSOR 1 and BANK 2 catalyst below thresh 04<TJ>renegade TJ Wrangler Technical Forum 22 12-31-2016 06:39 AM
Bank 1 vs. Bank 2 o2 sensor location rvsmith88 TJ Wrangler Technical Forum 16 01-28-2013 03:31 PM
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
chasing down bank 1 sensor 1 o2 loaderopp TJ Wrangler Technical Forum 9 01-01-2010 07:33 PM
O2 sensor, Bank 1 Sensor 2...which one is it? coyote runner TJ Wrangler Technical Forum 24 08-02-2007 06:19 PM
